소개
Removing this piece makes working inside of the computer easier. To replace this part (if it is broken) follow this guide.
필요한 것
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
