소개
If the processor fan stops working, and the system is overheating, Follow this guide to replace it.
필요한 것
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
