소개
Before working on any other article for replacement, start here to get instructions on how to remove the bottom cover and gain access to the system components.
필요한 것
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
다른 2명이 해당 안내서를 완성하였습니다.
