주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Thrive Front Camera Replacement
필요한 것
    1. Toshiba Thrive Front Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Make sure the lock switch for the back cover is unlocked.
      • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
      댓글 쓰기
    2. Toshiba Thrive Front Camera Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Thrive Front Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Remove back cover by prying away from the Thrive.
      • The easiest place to pry from is one of the two speakers.
      댓글 쓰기
    3. Toshiba Thrive Front Camera Replacement: 3 단계, 이미지 1개 중 1개
      • To remove the battery, make sure the lock switch is in the unlocked position.
      • The battery is unlocked when the switch is slid to the unlocked position.
      댓글 쓰기
    4. Toshiba Thrive Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Thrive Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Thrive Front Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Slide the battery switch release to the right.
      • While holding the switch in place, lift up the battery.
      댓글 쓰기
    1. Toshiba Thrive Front Camera Replacement, Midframe: 5 단계, 이미지 2개 중 1개 Toshiba Thrive Front Camera Replacement, Midframe: 5 단계, 이미지 2개 중 2개
      • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
      • All of these screws are identical so don't worry about getting them mixed up.
      댓글 쓰기
    2. Toshiba Thrive Front Camera Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Thrive Front Camera Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Thrive Front Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Start to gently pry the back of the device off, while leaving it loosely in place.
      • Be careful not to tear or damage the cables when removing the back.
      댓글 쓰기
    3. Toshiba Thrive Front Camera Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Thrive Front Camera Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Thrive Front Camera Replacement: 7 단계, 이미지 3개 중 3개
      • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
      댓글 쓰기
    4. Toshiba Thrive Front Camera Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Thrive Front Camera Replacement: 8 단계, 이미지 2개 중 2개
      • Carefully open the device like a book and lay the two halves beside each other.
      댓글 쓰기
    1. Toshiba Thrive Front Camera Replacement, Front Camera: 9 단계, 이미지 2개 중 1개 Toshiba Thrive Front Camera Replacement, Front Camera: 9 단계, 이미지 2개 중 2개
      • Separate the two halves of your Thrive
      • Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
      댓글 쓰기
    2. Toshiba Thrive Front Camera Replacement: 10 단계, 이미지 1개 중 1개
      • With a spudger, disconnect the cable connecting the camera to the motherboard.
      댓글 쓰기
    3. Toshiba Thrive Front Camera Replacement: 11 단계, 이미지 2개 중 1개 Toshiba Thrive Front Camera Replacement: 11 단계, 이미지 2개 중 2개
      • Lift up the LCD from the screen and place it on the side
      댓글 쓰기
    4. Toshiba Thrive Front Camera Replacement: 12 단계, 이미지 2개 중 1개 Toshiba Thrive Front Camera Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
      • Lift up the camera from the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Kason
회원 가입일: 09/22/14
1,120 평판
안내서 5개를 작성함
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 회원
USFT-BROWN-F14S10G1
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 647
