주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Transforming High-Rise Pants into Low-Rise Style by Hand
필요한 것
  1. Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: 1 단계, 이미지 2개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: 1 단계, 이미지 2개 중 2개
    • Begin by turning pants inside out and laying flat.
    댓글 쓰기
  2. Transforming High-Rise Pants into Low-Rise Style by Hand: 2 단계, 이미지 3개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 2 단계, 이미지 3개 중 2개 Transforming High-Rise Pants into Low-Rise Style by Hand: 2 단계, 이미지 3개 중 3개
    • Line up the seams to match on both sides.
    • Mark where you would like the new bottom of your pants to sit.
    • Using a straight edge, mark a line going down from the initial mark down to the leg of the pants.
    댓글 쓰기
  3. Transforming High-Rise Pants into Low-Rise Style by Hand: 3 단계, 이미지 3개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 3 단계, 이미지 3개 중 2개 Transforming High-Rise Pants into Low-Rise Style by Hand: 3 단계, 이미지 3개 중 3개
    • After the guide lines have been drawn out, cut off the fabric marked off leaving roughly 1cm for seam allowance.
    댓글 쓰기
  4. Transforming High-Rise Pants into Low-Rise Style by Hand: 4 단계, 이미지 2개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 4 단계, 이미지 2개 중 2개
    • Line up the fabric on both sides and pin together keeping the fabric in line.
    댓글 쓰기
  5. Transforming High-Rise Pants into Low-Rise Style by Hand: 5 단계, 이미지 3개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 5 단계, 이미지 3개 중 2개 Transforming High-Rise Pants into Low-Rise Style by Hand: 5 단계, 이미지 3개 중 3개
    • Thread your needle with a thread close to the color of the pants you are altering.
    • Tie the ends of the thread into a knot large enough to not go through the fabric being sewn.
    댓글 쓰기
  6. Transforming High-Rise Pants into Low-Rise Style by Hand: 6 단계, 이미지 2개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 6 단계, 이미지 2개 중 2개
    • Insert the needle into the bottom of the marked line to begin your stitch.
    댓글 쓰기
  7. Transforming High-Rise Pants into Low-Rise Style by Hand: 7 단계, 이미지 3개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 7 단계, 이미지 3개 중 2개 Transforming High-Rise Pants into Low-Rise Style by Hand: 7 단계, 이미지 3개 중 3개
    • Pull thread through the fabric and reinsert leaving about 1mm in between.
    • Insert the needle on the back side of the fabric about 1mm away from the previous stitch.
    • Insert the needle back into the initial stitch to create a backstitch.
    댓글 쓰기
  8. Transforming High-Rise Pants into Low-Rise Style by Hand: 8 단계, 이미지 3개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 8 단계, 이미지 3개 중 2개 Transforming High-Rise Pants into Low-Rise Style by Hand: 8 단계, 이미지 3개 중 3개
    • Continue backstitching all around the marked line.
    • Tie off the thread once you reach the end by tying a knot into the final stitch.
    댓글 쓰기
  9. Transforming High-Rise Pants into Low-Rise Style by Hand: 9 단계, 이미지 2개 중 1개 Transforming High-Rise Pants into Low-Rise Style by Hand: 9 단계, 이미지 2개 중 2개
    • Flip pants right side out and enjoy your new low-rise pants!
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Addison Cavenee
회원 가입일: 01/21/25
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 47
전체 시간: 740
