주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Treblab HD77 Battery Replacement
필요한 것
    1. Treblab HD77 Battery Replacement, Surround: 1 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement, Surround: 1 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement, Surround: 1 단계, 이미지 3개 중 3개
      • Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
      댓글 쓰기
    2. Treblab HD77 Battery Replacement: 2 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 2 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
      • There is a layer of adhesive between the plastic ring and the rubber surround beneath it.
      댓글 쓰기
    3. Treblab HD77 Battery Replacement: 3 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 3 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
      • Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
      • There is a layer of adhesive between the surround and the plastic housing it is resting on.
      댓글 쓰기
    1. Treblab HD77 Battery Replacement, LED Light: 4 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement, LED Light: 4 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement, LED Light: 4 단계, 이미지 3개 중 3개
      • Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
      • There are four points where adhesive is used to hold the LED light strip down.
      • Lift up the LED light strip from the plastic casing.
      댓글 쓰기
    2. Treblab HD77 Battery Replacement: 5 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 5 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Flip the LED light strip upside down to see where the cord is plugged in.
      • Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
      • The cord is very thin and lightweight so use caution when handling.
      댓글 쓰기
    1. Treblab HD77 Battery Replacement, Battery: 6 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement, Battery: 6 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement, Battery: 6 단계, 이미지 3개 중 3개
      • Using a Phillips #0 screwdriver, remove all four 10mm screws that were exposed by removing the LED light strip.
      • Lift the plastic ring once all the screws have been removed.
      • The screws are very tiny and can fall inside the device if they are not handled carefully.
      • Repeat steps 1-6 for the opposite side.
      댓글 쓰기
    2. Treblab HD77 Battery Replacement: 7 단계, 이미지 2개 중 1개 Treblab HD77 Battery Replacement: 7 단계, 이미지 2개 중 2개
      • Slide the inner electronics casing out from the outer tubing encasing it.
      댓글 쓰기
    3. Treblab HD77 Battery Replacement: 8 단계, 이미지 2개 중 1개 Treblab HD77 Battery Replacement: 8 단계, 이미지 2개 중 2개
      • Unscrew the six 10mm screws holding the two halves of the electronics casing together using a Phillips #0 screwdriver.
      댓글 쓰기
    4. Treblab HD77 Battery Replacement: 9 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 9 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 9 단계, 이미지 3개 중 3개
      • Insert the blade of a precision knife in between the edge of the rubber button cover and the extruded edges holding it in place.
      • Gently trace around the edge until you feel the cover beginning to loosen, and then slowly peel the cover up.
      • Be careful to not apply too much pressure with the blade, as there is a circuit board directly underneath the cover. There is also a layer of strong adhesive between the circuit board and the cover.
      댓글 쓰기
    5. Treblab HD77 Battery Replacement: 10 단계, 이미지 2개 중 1개 Treblab HD77 Battery Replacement: 10 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, unscrew the six 5mm screws holding the circuit board in place.
      댓글 쓰기
    6. Treblab HD77 Battery Replacement: 11 단계, 이미지 2개 중 1개 Treblab HD77 Battery Replacement: 11 단계, 이미지 2개 중 2개
      • Turn the speaker over to the side with the charging port dock, and gently pull the two halves apart by firmly grasping each half until they separate.
      댓글 쓰기
    7. Treblab HD77 Battery Replacement: 12 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 12 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 12 단계, 이미지 3개 중 3개
      • Pinch the thin wire under the circuit board that connects it to the motherboard, and gently remove the wire from the circuit board.
      댓글 쓰기
    8. Treblab HD77 Battery Replacement: 13 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 13 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 13 단계, 이미지 3개 중 3개
      • Orient the speaker so the motherboard is on the bottom half, facing up, and the circuit board cutout is facing you.
      • Using your thumb and pointer finger, grip the plug connected to the large red and black wires just below the extruded tip, and gently lift until the plug comes out.
      댓글 쓰기
    9. Treblab HD77 Battery Replacement: 14 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 14 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 14 단계, 이미지 3개 중 3개
      • Using your thumb and pointer finger, grip the plug connected to the smaller red and black wires just below the extruded tip, and gently lift until the plug comes out.
      댓글 쓰기
    10. Treblab HD77 Battery Replacement: 15 단계, 이미지 3개 중 1개 Treblab HD77 Battery Replacement: 15 단계, 이미지 3개 중 2개 Treblab HD77 Battery Replacement: 15 단계, 이미지 3개 중 3개
      • The battery is located on the half without the motherboard and has a layer of foam surrounding it.
      • Lift the battery out of the shell using your thumb on the edge of the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matthew Szabo
회원 가입일: 11/04/25
775 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 회원
UMASSD-BISWOKARMA-F25S3G5
5 회원들
안내서 35개를 작성함
1가이드 댓글
any ideas what the batteries are?
Cheffrank Mach - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 48
전체 시간: 354
