주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Treblab HD77 LED Light Replacement
필요한 것
    1. Treblab HD77 LED Light Replacement, Surround: 1 단계, 이미지 3개 중 1개 Treblab HD77 LED Light Replacement, Surround: 1 단계, 이미지 3개 중 2개 Treblab HD77 LED Light Replacement, Surround: 1 단계, 이미지 3개 중 3개
      • Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
      댓글 쓰기
    2. Treblab HD77 LED Light Replacement: 2 단계, 이미지 3개 중 1개 Treblab HD77 LED Light Replacement: 2 단계, 이미지 3개 중 2개 Treblab HD77 LED Light Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
      • There is a layer of adhesive between the plastic ring and the rubber surround beneath it.
      댓글 쓰기
    3. Treblab HD77 LED Light Replacement: 3 단계, 이미지 3개 중 1개 Treblab HD77 LED Light Replacement: 3 단계, 이미지 3개 중 2개 Treblab HD77 LED Light Replacement: 3 단계, 이미지 3개 중 3개
      • Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
      • Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
      • There is a layer of adhesive between the surround and the plastic housing it is resting on.
      댓글 쓰기
    1. Treblab HD77 LED Light Replacement, LED Light: 4 단계, 이미지 3개 중 1개 Treblab HD77 LED Light Replacement, LED Light: 4 단계, 이미지 3개 중 2개 Treblab HD77 LED Light Replacement, LED Light: 4 단계, 이미지 3개 중 3개
      • Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
      • There are four points where adhesive is used to hold the LED light strip down.
      • Lift up the LED light strip from the plastic casing.
      댓글 쓰기
    2. Treblab HD77 LED Light Replacement: 5 단계, 이미지 3개 중 1개 Treblab HD77 LED Light Replacement: 5 단계, 이미지 3개 중 2개 Treblab HD77 LED Light Replacement: 5 단계, 이미지 3개 중 3개
      • Flip the LED light strip upside down to see where the cord is plugged in.
      • Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
      • The cord is very thin and lightweight so use caution when handling.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Matthew Szabo
회원 가입일: 11/04/25
775 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 회원
UMASSD-BISWOKARMA-F25S3G5
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 160
