주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trek 4300 Bicycle Front Reflector Replacement
필요한 것
    1. Trek 4300 Bicycle Front Reflector Replacement, Loosen the Reflector: 1 단계, 이미지 1개 중 1개
      • Stand facing the front of the bike, bracing the front wheel between knees.
      • Using a Phillips-head screwdriver, loosen the screw holding the reflector in place.
      댓글 쓰기
    2. Trek 4300 Bicycle Front Reflector Replacement, Remove Bracket: 2 단계, 이미지 2개 중 1개 Trek 4300 Bicycle Front Reflector Replacement, Remove Bracket: 2 단계, 이미지 2개 중 2개
      • Remove the screw. Bracket should now be able to rotate freely around the handlebar.
      • Separate the flat pieces of the bracket creating about a 1" gap.
      • Push the bracket away from you so it slides off the handlebar. Bracket should pop off the handlebar and return to original shape.
      댓글 쓰기
    3. Trek 4300 Bicycle Front Reflector Replacement, Replace Bracket: 3 단계, 이미지 1개 중 1개
      • To replace the new reflector hold the bracket on the side of the handlebar opposite you with the flat pieces facing toward the front of the bike.
      • Spread the flat pieces apart and position the bracket so that the top flat piece will go over the top of the handlebar and the bottom piece will go underneath the handlebar.
      • Using light to moderate force, pull the bracket towards you so that it maneuvers around the bar. The bracket should now be reattached to the handlebar but spinning freely.
      댓글 쓰기
    4. Trek 4300 Bicycle Front Reflector Replacement, Tighten Bracket: 4 단계, 이미지 1개 중 1개
      • Holding the reflector so that it faces forwards, insert the screw so that it goes through the hole of both flat pieces of the bracket.
      • Using a Phillips-head screwdriver, tighten the bracket until it is snug around the handlebar.
      • Pull up and down lightly on the reflector to make sure it is securely in place.
      댓글 쓰기
결론
It is important to remember that when replacing reflectors, any reflectors facing forward should be white/clear and any reflector facing backward should be red so cars and and other bikers know which direction you are heading.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Emily OConnor
회원 가입일: 10/13/14
500 평판
안내서 4개를 작성함
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014 회원
CLEM-BENSON-F14S3G2
4 회원들
안내서 72개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 47
전체 시간: 2,284
