주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trek 820 Front Wheel Removal
    1. Trek 820 Front Wheel Removal, Front Wheel: 1 단계, 이미지 2개 중 1개 Trek 820 Front Wheel Removal, Front Wheel: 1 단계, 이미지 2개 중 2개
      • Facing your bike, straddle your front wheel between your knees.
      • Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
      • Since the tire is normally wider than the space between the brake pads, you must first release the tension in the brake wire. To do this, run your right hand under both brake calipers and push them inwards towards one another.
      댓글 쓰기
    2. Trek 820 Front Wheel Removal: 2 단계, 이미지 2개 중 1개 Trek 820 Front Wheel Removal: 2 단계, 이미지 2개 중 2개
      • With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand.
      • The brake will now be open wide enough to permit removal of the wheel.
      댓글 쓰기
    3. Trek 820 Front Wheel Removal: 3 단계, 이미지 2개 중 1개 Trek 820 Front Wheel Removal: 3 단계, 이미지 2개 중 2개
      • Find the quick release lever on the outside of the bike's fork on the right hand side. Flip the lever down and turn the lever counter clockwise, loosening the lever until it comes off.
      댓글 쓰기
    4. Trek 820 Front Wheel Removal: 4 단계, 이미지 1개 중 1개
      • After the quick release lever is removed, the wheel can be separated from the front fork.
      댓글 쓰기
      • In reassembling the wheel to the bike, perform the steps in reverse order.
      • With the axle all the way into the fork slots, tighten the quick release lever into the fork end securely. It should take a modest amount of force applied to tighten the axle to the fork.
      • Squeeze the brake calipers together and return the cable noodle back into the holder.
      • Make sure you go back, and check to make sure its snug so that the wheel has no way of coming back off.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Kaveh Karimiyanha
회원 가입일: 09/24/12
822 평판
안내서 7개를 작성함
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G1
5 회원들
안내서 63개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 94
전체 시간: 13,524
