주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trek 820 Handlebars Replacement
필요한 것
    1. Trek 820 Handlebars Replacement, Handlebar and stem: 1 단계, 이미지 2개 중 1개 Trek 820 Handlebars Replacement, Handlebar and stem: 1 단계, 이미지 2개 중 2개
      • Use a 3/16" Allen Wrench to remove the silver cap.
      댓글 쓰기
    2. Trek 820 Handlebars Replacement: 2 단계, 이미지 1개 중 1개
      • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
      댓글 쓰기
    3. Trek 820 Handlebars Replacement: 3 단계, 이미지 2개 중 1개 Trek 820 Handlebars Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the handlebar by lifting vertically away from the frame.
      • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
      댓글 쓰기
    4. Trek 820 Handlebars Replacement: 4 단계, 이미지 2개 중 1개 Trek 820 Handlebars Replacement: 4 단계, 이미지 2개 중 2개
      • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
      • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
      댓글 쓰기
    5. Trek 820 Handlebars Replacement: 5 단계, 이미지 1개 중 1개
      • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
      • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
      • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
10다른 기여자 명과 함께
Kaveh Karimiyanha
회원 가입일: 09/24/12
822 평판
안내서 7개를 작성함
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G1
5 회원들
안내서 49개를 작성함
1가이드 댓글
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 73
전체 시간: 6,918
