주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trio AXS 3G Screen Replacement
필요한 것
    1. Trio AXS 3G Screen Replacement, Back Case: 1 단계, 이미지 1개 중 1개
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      댓글 쓰기
    2. Trio AXS 3G Screen Replacement: 2 단계, 이미지 2개 중 1개 Trio AXS 3G Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      댓글 쓰기
    3. Trio AXS 3G Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      댓글 쓰기
    1. Trio AXS 3G Screen Replacement, Screen: 4 단계, 이미지 1개 중 1개
      • The motherboard and battery will have to be removed to expose the metal panel underneath.
      댓글 쓰기
    2. Trio AXS 3G Screen Replacement: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Use the plastic card to pry the battery away from the device.
      • The battery is attached to the tablet by glue.
      댓글 쓰기
    3. Trio AXS 3G Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Peel off the battery from the device and set aside.
      • The battery is connected to the motherboard by two wires. Be careful not to sever the connection.
      댓글 쓰기
    4. Trio AXS 3G Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Using a #000 screwdriver, unscrew the five 4mm and 3 mm screws connecting the top portion of the motherboard to the device.
      댓글 쓰기
    5. Trio AXS 3G Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Disconnect the silver tape that attaches the motherboard to the metal panel.
      댓글 쓰기
    6. Trio AXS 3G Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Disconnect the ribbon from the bottom portion of the motherboard.
      댓글 쓰기
    7. Trio AXS 3G Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the motherboard and set aside.
      댓글 쓰기
    8. Trio AXS 3G Screen Replacement: 11 단계, 이미지 1개 중 1개
      • The smaller portion of the motherboard is located at the bottom with the speaker.
      • Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
      댓글 쓰기
    9. Trio AXS 3G Screen Replacement: 12 단계, 이미지 2개 중 1개 Trio AXS 3G Screen Replacement: 12 단계, 이미지 2개 중 2개
      • Located towards the bottom, carefully remove the yellow film.
      댓글 쓰기
    10. Trio AXS 3G Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Gently disconnect the small ribbon found underneath the film.
      댓글 쓰기
    11. Trio AXS 3G Screen Replacement: 14 단계, 이미지 1개 중 1개
      • There is another connection found underneath this portion of the motherboard.
      • Lifting up the motherboard, disconnect the second ribbon found underneath.
      댓글 쓰기
    12. Trio AXS 3G Screen Replacement: 15 단계, 이미지 1개 중 1개
      • Unscrew the two 4 mm #000 screws.
      댓글 쓰기
    13. Trio AXS 3G Screen Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the speaker and bottom portion of the motherboard.
      댓글 쓰기
    14. Trio AXS 3G Screen Replacement: 17 단계, 이미지 1개 중 1개
      • At this stage, almost all inside components should be removed (as shown).
      • Using a screwdriver size #000, remove the four 4 mm screws found at each corner of the metal panel if you haven't gotten them already.
      댓글 쓰기
    15. Trio AXS 3G Screen Replacement: 18 단계, 이미지 3개 중 1개 Trio AXS 3G Screen Replacement: 18 단계, 이미지 3개 중 2개 Trio AXS 3G Screen Replacement: 18 단계, 이미지 3개 중 3개
      • Use the plastic card to separate the metal panel from the screen component.
      댓글 쓰기
    16. Trio AXS 3G Screen Replacement: 19 단계, 이미지 1개 중 1개
      • Separate memory card from screen.
      댓글 쓰기
    17. Trio AXS 3G Screen Replacement: 20 단계, 이미지 2개 중 1개 Trio AXS 3G Screen Replacement: 20 단계, 이미지 2개 중 2개
      • Use the plastic card to separate screen component from front panel.
      댓글 쓰기
    18. Trio AXS 3G Screen Replacement: 21 단계, 이미지 1개 중 1개
      • Use the plastic card to separate the glass from the front panel.
      • Once the glass is removed, the new glass can be fitted to the front panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Michaela Causey
회원 가입일: 09/20/17
328 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 31
전체 시간: 1,328
