주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trio STEALTH-9 Back Cover Replacement
필요한 것
    1. Trio STEALTH-9 Back Cover Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the two Phillips #00 screws on the side of the tablet.
      댓글 쓰기
    2. Trio STEALTH-9 Back Cover Replacement: 2 단계, 이미지 1개 중 1개
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      댓글 쓰기
    3. Trio STEALTH-9 Back Cover Replacement: 3 단계, 이미지 1개 중 1개
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      댓글 쓰기
    4. Trio STEALTH-9 Back Cover Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order with your replacement cover!
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mei Liang
회원 가입일: 01/29/15
228 평판
안내서 2개를 작성함
Clemson, Team 15-5, Shirley Winter 2015 Clemson, Team 15-5, Shirley Winter 2015 회원
CLEM-SHIRLEY-W15S15G5
4 회원들
안내서 4개를 작성함
2가이드 댓글
Tengo.una y costo tiene el.displey
eliehtmaria - 답글 공유
Deseo.saber el.c
eliehtmaria - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 31
전체 시간: 1,538
