주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trio STEALTH-9 Battery Replacement
필요한 것
    1. Trio STEALTH-9 Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the two Phillips #00 screws on the side of the tablet.
      댓글 쓰기
    2. Trio STEALTH-9 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      댓글 쓰기
    3. Trio STEALTH-9 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      댓글 쓰기
    4. Trio STEALTH-9 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      댓글 쓰기
    1. Trio STEALTH-9 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • With the cover removed, slowly pull the electrical tape away as shown.
      댓글 쓰기
    2. Trio STEALTH-9 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Slowly pull the Battery away from the tablet frame.
      댓글 쓰기
    3. Trio STEALTH-9 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Prepare your Soldering Iron and Removal Tools.
      • Contact the iron with each of the battery leads, and pull the lead away from the board.
      • Remove any excess solder as needed.
      댓글 쓰기
    4. Trio STEALTH-9 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
      • Apply heat and solder to each lead individually.
      • Remove any excess solder if flooding occurs.
      댓글 쓰기
결론
To replace the battery, you must re-solder the leads on the battery into the motherboard. You MUST make sure that the leads were in the correct order as when you started.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
[deleted]
회원 가입일: 01/29/15
415 평판
안내서 3개를 작성함
1가이드 댓글
Is it possible that the wiring to the battery just became loose and I could use these same directions and reconnect or solder (or do both?) The existing battery ?
Jessie ussery - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 26
전체 시간: 1,835
