주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trio STEALTH-9 Motherboard Replacement
필요한 것
    1. Trio STEALTH-9 Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the two Phillips #00 screws on the side of the tablet.
      댓글 쓰기
    2. Trio STEALTH-9 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      댓글 쓰기
    3. Trio STEALTH-9 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      댓글 쓰기
    4. Trio STEALTH-9 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      댓글 쓰기
    1. Trio STEALTH-9 Motherboard Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • With the cover removed, slowly pull the electrical tape away as shown.
      댓글 쓰기
    2. Trio STEALTH-9 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Slowly pull the Battery away from the tablet frame.
      댓글 쓰기
    3. Trio STEALTH-9 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Prepare your Soldering Iron and Removal Tools.
      • Contact the iron with each of the battery leads, and pull the lead away from the board.
      • Remove any excess solder as needed.
      댓글 쓰기
    4. Trio STEALTH-9 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
      • Apply heat and solder to each lead individually.
      • Remove any excess solder if flooding occurs.
      댓글 쓰기
    1. Trio STEALTH-9 Motherboard Replacement, Camera: 9 단계, 이미지 2개 중 1개 Trio STEALTH-9 Motherboard Replacement, Camera: 9 단계, 이미지 2개 중 2개
      • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
      댓글 쓰기
    2. Trio STEALTH-9 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Trio STEALTH-9 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
      댓글 쓰기
    3. Trio STEALTH-9 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Trio STEALTH-9 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
      • Remove the camera from the frame and replace as needed.
      댓글 쓰기
    1. Trio STEALTH-9 Motherboard Replacement, Speaker: 12 단계, 이미지 1개 중 1개
      • Slowly remove the electrical tape holding down the Speaker wires.
      댓글 쓰기
    2. Trio STEALTH-9 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Trio STEALTH-9 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the #00 screw on the Speaker mount and remove the Speaker mount.
      댓글 쓰기
    3. Trio STEALTH-9 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
      • Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
      • Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
      댓글 쓰기
    1. Trio STEALTH-9 Motherboard Replacement, Motherboard: 15 단계, 이미지 1개 중 1개
      • Prepare your Desoldering Tools. Remove the grey wire attached to the Motherboard.
      댓글 쓰기
    2. Trio STEALTH-9 Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Trio STEALTH-9 Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Trio STEALTH-9 Motherboard Replacement: 16 단계, 이미지 3개 중 3개
      • Remove the three #00 Screws holding down the Motherboard.
      댓글 쓰기
    3. Trio STEALTH-9 Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Trio STEALTH-9 Motherboard Replacement: 17 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of Tweezers to carefully pull the side buttons away from the frame.
      • Use the same Tweezers to carefully pull the microphone away from the front of the frame.
      댓글 쓰기
    4. Trio STEALTH-9 Motherboard Replacement: 18 단계, 이미지 3개 중 1개 Trio STEALTH-9 Motherboard Replacement: 18 단계, 이미지 3개 중 2개 Trio STEALTH-9 Motherboard Replacement: 18 단계, 이미지 3개 중 3개
      • Use your fingernails or a plastic opening tool to remove any remaining ribbon cables from the Motherboard.
      댓글 쓰기
    5. Trio STEALTH-9 Motherboard Replacement: 19 단계, 이미지 1개 중 1개
      • With the cables removed, lift the Motherboard off of the frame.
      • Repair or replace the Motherboard as needed.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order while being careful with the electronics on your repaired/replaced Motherboard.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mei Liang
회원 가입일: 01/29/15
228 평판
안내서 2개를 작성함
Clemson, Team 15-5, Shirley Winter 2015 Clemson, Team 15-5, Shirley Winter 2015 회원
CLEM-SHIRLEY-W15S15G5
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 29
전체 시간: 997
