소개
If you are having issues with your Trio Stealth Pro 9.7" and find the motherboard needs to be replaced, whether it be malfunctioning or outdated, you can use this guide to achieve this goal.
The motherboard is a vital piece of any computer. It is in charge of many things, including distributing energy from the power supply and facilitates communication between the various hardware components.
Signs of a faulty motherboard can include failing to boot, random shutdowns or freezes, overheating, strange noises, and a burning smell.
Be sure the device is fully shut off before beginning the repair. For putting a new motherboard in, you may find you need to solder the cut wires.
필요한 것
Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
다른 2명이 해당 안내서를 완성하였습니다.
