주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Trunk LED Tailgate Strip Light Installation
필요한 것
    1. Trunk LED Tailgate Strip Light Installation, Cleaning: 1 단계, 이미지 2개 중 1개 Trunk LED Tailgate Strip Light Installation, Cleaning: 1 단계, 이미지 2개 중 2개
      • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
      • Use soap and water to scrub the area clean since that place is normally dirty.
      댓글 쓰기
    2. Trunk LED Tailgate Strip Light Installation, Mounting time: 2 단계, 이미지 2개 중 1개 Trunk LED Tailgate Strip Light Installation, Mounting time: 2 단계, 이미지 2개 중 2개
      • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
      • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
      • Straighten the LED strip and peel adhesive.
      • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
      댓글 쓰기
    3. Trunk LED Tailgate Strip Light Installation, Wire tapping: 3 단계, 이미지 3개 중 1개 Trunk LED Tailgate Strip Light Installation, Wire tapping: 3 단계, 이미지 3개 중 2개 Trunk LED Tailgate Strip Light Installation, Wire tapping: 3 단계, 이미지 3개 중 3개
      • Tap reverse light wire.
      • You will need to remove either side of the tail light to locate the reverse light.
      • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
      댓글 쓰기
    4. Trunk LED Tailgate Strip Light Installation, Find the connector: 4 단계, 이미지 2개 중 1개 Trunk LED Tailgate Strip Light Installation, Find the connector: 4 단계, 이미지 2개 중 2개
      • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
      • You will find the trailer light connector near the tow hitch.
      댓글 쓰기
    5. Trunk LED Tailgate Strip Light Installation, Test and enjoy: 5 단계, 이미지 3개 중 1개 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 5 단계, 이미지 3개 중 2개 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 5 단계, 이미지 3개 중 3개
      • Hide the wires or zip-tie them.
      • Check the trunk LED tailgate lamp to make sure everything works.
      댓글 쓰기
결론
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Eric Wu
회원 가입일: 01/21/15
3,600 평판
안내서 23개를 작성함
21가이드 댓글
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - 답글 공유
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 - 답글 공유
Anyone have the answer to this problem yet?
Trevor G - 답글 공유
I'm having the same problem!
Richie - 답글 공유
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 35
지난 30일: 117
전체 시간: 44,624
