주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tungsten E Power Button Repair
필요한 것
  1. Tungsten E Power Button Repair, Tungsten E Disassembly: 1 단계, 이미지 2개 중 1개 Tungsten E Power Button Repair, Tungsten E Disassembly: 1 단계, 이미지 2개 중 2개
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Power Button Repair: 2 단계, 이미지 3개 중 1개 Tungsten E Power Button Repair: 2 단계, 이미지 3개 중 2개 Tungsten E Power Button Repair: 2 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Power Button Repair: 3 단계, 이미지 2개 중 1개 Tungsten E Power Button Repair: 3 단계, 이미지 2개 중 2개
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Power Button Repair: 4 단계, 이미지 2개 중 1개 Tungsten E Power Button Repair: 4 단계, 이미지 2개 중 2개
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Power Button Repair: 5 단계, 이미지 3개 중 1개 Tungsten E Power Button Repair: 5 단계, 이미지 3개 중 2개 Tungsten E Power Button Repair: 5 단계, 이미지 3개 중 3개
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Power Button Repair: 6 단계, 이미지 1개 중 1개
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
  7. Tungsten E Power Button Repair, Tungsten E Power Button Repair: 7 단계, 이미지 1개 중 1개
  8. Tungsten E Power Button Repair: 8 단계, 이미지 1개 중 1개
    • On the motherboard, find the power button near the upper right corner.
    • Check for disconnection of the power button.
  9. Tungsten E Power Button Repair: 9 단계, 이미지 1개 중 1개
    • Use soldering iron to reattach the damaged power button to the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kathleen Hix
회원 가입일: 01/21/10
49 평판
안내서 2개를 작성함
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 회원
CPSU-MANESS-W10S13G22
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 72
전체 시간: 5,542
