주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Turtle Beach Elite Pro Left Speaker Replacement
필요한 것
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Ear Cushion: 1 단계, 이미지 1개 중 1개
      • Firmly pinch ear cushion between thumb and forefinger.
      • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
      • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
      댓글 쓰기
    2. Turtle Beach Elite Pro Left Speaker  Replacement: 2 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Left Speaker  Replacement: 2 단계, 이미지 2개 중 2개
      • Rotate ear cushion counter-clockwise about half an inch.
      • The ear cushion should audibly snap out of place.
      • After it has audibly snapped out of place, lift the ear cushion off of the device.
      • During reassembly, rotate the ear cushion clockwise.
      댓글 쓰기
    3. Turtle Beach Elite Pro Left Speaker  Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Left Speaker  Replacement: 3 단계, 이미지 2개 중 2개
      • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
      • Make sure that both the ear cushion and the orange plate have the same designation.
      • Once the pegs are aligned, push the new ear cushion in place.
      댓글 쓰기
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Left Speaker: 4 단계, 이미지 1개 중 1개
      • Remove the left ear cushion completely from the headset.
      • The left ear cushion will be on the side of the headset where the microphone and audio control is attached.
      댓글 쓰기
    2. Turtle Beach Elite Pro Left Speaker  Replacement: 5 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Left Speaker  Replacement: 5 단계, 이미지 2개 중 2개
      • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
      댓글 쓰기
    3. Turtle Beach Elite Pro Left Speaker  Replacement: 6 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Left Speaker  Replacement: 6 단계, 이미지 2개 중 2개
      • Use the opening tool to separate the orange plate from the black base plate.
      • Focus on the wires that are connected to the speaker.
      댓글 쓰기
    4. Turtle Beach Elite Pro Left Speaker  Replacement: 7 단계, 이미지 1개 중 1개
      • Using wire cutters, cut the two wires that are attached to the speaker.
      • Make sure to cut the wires as close to the speaker as possible, because these wires will be used in the next step.
      댓글 쓰기
    5. Turtle Beach Elite Pro Left Speaker  Replacement: 8 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Left Speaker  Replacement: 8 단계, 이미지 2개 중 2개
      • Replace the old speaker with the new speaker.
      • Using the soldering iron, solder the wires to the new speaker.
      • Make sure to solder the wires to their original locations on the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexis Uribe
회원 가입일: 03/24/17
528 평판
안내서 4개를 작성함
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G1
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 3,679
