주요 콘텐츠로 건너뛰기
Turtle Beach Recon 200 Gen 2 Audio Repair
필요한 것
  1. Turtle Beach Recon 200 Gen 2 Audio Repair, Turtle Beach Recon 200 Gen 2 Audio Repair: 1 단계, 이미지 1/2 Turtle Beach Recon 200 Gen 2 Audio Repair, Turtle Beach Recon 200 Gen 2 Audio Repair: 1 단계, 이미지 2/2
    • Before you begin, power off your headset and unplug it from the charging cable.
    • Place the headset on a flat surface.
    • Grab the outer layer of the cushion and gently pull each ear cup off the headset.
  2. Turtle Beach Recon 200 Gen 2 Audio Repair: 2 단계, 이미지 1/3 Turtle Beach Recon 200 Gen 2 Audio Repair: 2 단계, 이미지 2/3 Turtle Beach Recon 200 Gen 2 Audio Repair: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove three screws from each speaker cover.
    • Use proper screwdriver practices. If you strip a screw, review this guide for tips on how to remove a stripped screw.
    • Place the screws in a secure area. You will need them for reassembly.
  3. Turtle Beach Recon 200 Gen 2 Audio Repair: 3 단계, 이미지 1/3 Turtle Beach Recon 200 Gen 2 Audio Repair: 3 단계, 이미지 2/3 Turtle Beach Recon 200 Gen 2 Audio Repair: 3 단계, 이미지 3/3
    • Use a spudger to gently pry the speakers from the headset.
    • The speaker is connected to the motherboard by a cable so do not pull the speaker off or it will rip the wire and further damage your headphones.
    • Do not push the prying tool inside the cups, or you could damage the internal components.
  4. Turtle Beach Recon 200 Gen 2 Audio Repair: 4 단계, 이미지 1/2 Turtle Beach Recon 200 Gen 2 Audio Repair: 4 단계, 이미지 2/2
    • Set the speaker to the side without pulling the wires or cables.
    • Check if any dust has gotten into the headset.
    • If so, use a dust blower and/or ESD safe cleaning brush to clean off the dust.
    • If a wire is broken or ripped, use tweezers to hold it and identity where the wire is meant to be.
    • Do not attempt to rip or pull any damaged or exposed wire(s).
  5. Turtle Beach Recon 200 Gen 2 Audio Repair: 5 단계, 이미지 1/2 Turtle Beach Recon 200 Gen 2 Audio Repair: 5 단계, 이미지 2/2
    • Use the multimeter to check for any outage or shortage of current.
    • Check any and every wire and pins you think are faulty that could be the cause of the issue.
    • Most multimeter devices have sharp points, be careful when checking for current. Touch the surface as lightly as possible.
  6. Turtle Beach Recon 200 Gen 2 Audio Repair: 6 단계, 이미지 1/2 Turtle Beach Recon 200 Gen 2 Audio Repair: 6 단계, 이미지 2/2
    • Use a soldering iron to re-solder any wires that have detached from the motherboard.
    • Keep your hands as steady as possible and ensure that the wires are attached to the correct solder joint.
    • The solder might release an odd smell. If possible, wear a mask to avoid inhaling fumes.
    • The end point of the soldering kit will be very hot, do not touch it with your bare hands.
  7. Turtle Beach Recon 200 Gen 2 Audio Repair: 7 단계, 이미지 1/3 Turtle Beach Recon 200 Gen 2 Audio Repair: 7 단계, 이미지 2/3 Turtle Beach Recon 200 Gen 2 Audio Repair: 7 단계, 이미지 3/3
    • Test the headset to ensure everything is working. Plug the headset into any device with a AUX input.
    • Test the audio on a low volume setting and slowly raise it to full volume.
    • Replace the speakers.
    • Make sure they are is sitting correctly on the headset so you can replace the screws without a problem.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Valadez
회원 가입일: 03/05/24
157 평판
안내서 1개 작성함
CSU Los Angeles, Team 7-4, Grodsky Spring 2024 CSU Los Angeles, Team 7-4, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S7G4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 62
