주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Turtle Beach Recon 70P Talkback Cable Replacement
필요한 것
    1. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: 1 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: 1 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: 1 단계, 이미지 3개 중 3개
      • Remove the left ear pad by following the steps from the ear pad replacement guide. earpad replacement guide.
      • Use a spudger to pry up and remove the black plastic cover.
      댓글 쓰기
    2. Turtle Beach Recon 70P Talkback Cable Replacement: 2 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 2 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips screwdriver to remove the two 5 mm screws that secure the motherboard.
      댓글 쓰기
    3. Turtle Beach Recon 70P Talkback Cable Replacement: 3 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 3 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 3 단계, 이미지 3개 중 3개
      • Cut the talkback cable below where it enters the speaker housing.
      • Remove the cut section of the talkback cable.
      댓글 쓰기
    4. Turtle Beach Recon 70P Talkback Cable Replacement: 4 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 4 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 4 단계, 이미지 3개 중 3개
      • You may need to move the speaker wire out of site so it will not block the motherboard.
      • Lift the motherboard up and out of the housing.
      • Take care not to strain the wires.
      댓글 쓰기
    5. Turtle Beach Recon 70P Talkback Cable Replacement: 5 단계, 이미지 2개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 5 단계, 이미지 2개 중 2개
      • Desolder all of the talkback cable motherboard connections.
      댓글 쓰기
    6. Turtle Beach Recon 70P Talkback Cable Replacement: 6 단계, 이미지 3개 중 1개 Turtle Beach Recon 70P Talkback Cable Replacement: 6 단계, 이미지 3개 중 2개 Turtle Beach Recon 70P Talkback Cable Replacement: 6 단계, 이미지 3개 중 3개
      • Feed the replacement talkback cable through the housing, then solder every wire onto the motherboard's connection points in the order they were initially found.
      • The purpose of each wire is designated in small text on the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Austin Hance
회원 가입일: 02/05/24
588 평판
안내서 4개를 작성함
1가이드 댓글
Thanks for the run down but could you please share what cable you used to replaced old one with? is it just 3.5mm jack, four pole extension cable which you stripped on one side ?
Bartosz Debski - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 45
전체 시간: 1,007
