주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Turtle Beach Recon Controller Front Buttons Replacement
필요한 것
    1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: 1 단계, 이미지 3개 중 1개 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: 1 단계, 이미지 3개 중 2개 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: 1 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
      • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
      댓글 쓰기
    2. Turtle Beach Recon Controller Front Buttons Replacement: 2 단계, 이미지 3개 중 1개 Turtle Beach Recon Controller Front Buttons Replacement: 2 단계, 이미지 3개 중 2개 Turtle Beach Recon Controller Front Buttons Replacement: 2 단계, 이미지 3개 중 3개
      • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
      • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
      댓글 쓰기
    1. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: 3 단계, 이미지 2개 중 1개 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: 3 단계, 이미지 2개 중 2개
      • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Turtle Beach Recon Controller Front Buttons Replacement: 4 단계, 이미지 2개 중 1개 Turtle Beach Recon Controller Front Buttons Replacement: 4 단계, 이미지 2개 중 2개
      • Use your fingers to grab the motherboard.
      • Gently pull the motherboard and joystick caps away from the face plate.
      댓글 쓰기
    3. Turtle Beach Recon Controller Front Buttons Replacement: 5 단계, 이미지 3개 중 1개 Turtle Beach Recon Controller Front Buttons Replacement: 5 단계, 이미지 3개 중 2개 Turtle Beach Recon Controller Front Buttons Replacement: 5 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
      댓글 쓰기
    1. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: 6 단계, 이미지 3개 중 1개 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: 6 단계, 이미지 3개 중 2개 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: 6 단계, 이미지 3개 중 3개
      • Gently remove front buttons from the face plate by hand.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mary Goodrow
회원 가입일: 03/22/24
716 평판
안내서 5개를 작성함
UMass Dartmouth, Team 6-1, Botvin Spring 2024 UMass Dartmouth, Team 6-1, Botvin Spring 2024 회원
UMASSD-BOTVIN-S24S6G1
3 회원들
안내서 60개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 46
전체 시간: 755
