주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Turtle Beach Stealth Ultra Front Facing Buttons Replacement
필요한 것
  1. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Back Plate: 1 단계, 이미지 2개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Back Plate: 1 단계, 이미지 2개 중 2개
    • Use tweezers to pull out rubber pieces in front of the screws.
    댓글 쓰기
  2. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 2 단계, 이미지 2개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 mm screws using a Phillips #00 screwdriver.
    댓글 쓰기
  3. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the sticker on the back of the plate.
    • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
    댓글 쓰기
  4. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 4 단계, 이미지 3개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 4 단계, 이미지 3개 중 2개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
    • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
    • Be cautious not to break the LCD screen while you move the opening tool around.
    댓글 쓰기
  5. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 5 단계, 이미지 3개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 5 단계, 이미지 3개 중 2개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Use an opening tool to detach the front plate from the back.
    • You may need to work the opening tool all the way around the seam between the two plates.
    댓글 쓰기
  6. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the 10 mm screws connecting the handles to the controller frame.
    댓글 쓰기
  7. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Detach the cables from the motherboard.
    댓글 쓰기
  8. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the yellow ribbon cable from the handle.
    댓글 쓰기
  9. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 9 단계, 이미지 2개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the six 10 mm screws connected to the motherboard using a Phillips #00 screwdriver.
    댓글 쓰기
  10. Turtle Beach Stealth Ultra Front Facing Buttons Replacement: 10 단계, 이미지 1개 중 1개
    • Gently pull the motherboard away from the frame.
    댓글 쓰기
  11. Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Front Facing Buttons: 11 단계, 이미지 2개 중 1개 Turtle Beach Stealth Ultra Front Facing Buttons Replacement, Front Facing Buttons: 11 단계, 이미지 2개 중 2개
    • Pull the buttons out from the front plate.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominic Dodge
회원 가입일: 09/09/25
814 평판
안내서 7개를 작성함
Utah Tech University, Team 1-7, McMurrin Fall 2025 Utah Tech University, Team 1-7, McMurrin Fall 2025 회원
UTAHTECH-MCMURRIN-F25S1G7
2 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 111
전체 시간: 605
