주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
UP! Plus 2 Nozzle Replacement
필요한 것
  1. UP! Plus 2 Nozzle Replacement, Turn on your printer: 1 단계, 이미지 1개 중 1개
    • Plug in the AC Power adapter and USB cable into the back of the printer.
    • Connect your printer to the computer via USB.
    • Turn on the printer and initialize it.
    댓글 쓰기
  2. UP! Plus 2 Nozzle Replacement, Verify the nozzle temperature: 2 단계, 이미지 1개 중 1개
    • Open the UP! software on your computer, and bring up the "maintenance window."
    • Under maintenance, click "extrude."
    • Then, verify if the nozzle temperature is rising by looking at the status box in the same maintenance window.
    댓글 쓰기
  3. UP! Plus 2 Nozzle Replacement, Remove nozzle: 3 단계, 이미지 2개 중 1개 UP! Plus 2 Nozzle Replacement, Remove nozzle: 3 단계, 이미지 2개 중 2개
    • The nozzle needs to be greater than 200 degrees Celsius before removal.
    • Before handling the nozzle please put on heat resistant gloves in order to prevent burns.
    • Using the 6mm hex wrench, apply force by pushing up to lock the nozzle into the wrench and turn counterclockwise to loosen the nozzle.
    댓글 쓰기
  4. UP! Plus 2 Nozzle Replacement, Attach the new nozzle: 4 단계, 이미지 1개 중 1개
    • Before attaching the new nozzle, make sure the temperature is still greater than 200 degrees Celsius.
    • Attach the new nozzle with the hex wrench by screwing it on in a clockwise manner.
    • If there is any extra plastic coming out of the extruder, cut it off before attaching the new nozzle.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
valerie boyer
회원 가입일: 10/12/14
508 평판
안내서 4개를 작성함
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014 회원
CPSU-MANESS-F14S14G31
4 회원들
안내서 5개를 작성함
1가이드 댓글
I have a problem with my UP PLUS 3D printer and I really need your help. First printer started to stop in the middle of the printing, then got to the point where I wasn’t even able to connect it to my laptop (it didn’t recognize it) and now, when I press Print, before even slicing completes, the software crashes and I have to reopen (basically I can’t print anything as every time I try, same thing happens). The weird part is that sometimes I can adjust the bed, heat up extruder, extract or retract filament from software but the moment I press print, it dies. PLEASE HELP!!!
Nima - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 34
전체 시간: 3,167
