주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
UP! Plus 2 Power Supply Replacement
필요한 것
  1. UP! Plus 2 Power Supply Replacement, Plug in the Power Supply: 1 단계, 이미지 2개 중 1개 UP! Plus 2 Power Supply Replacement, Plug in the Power Supply: 1 단계, 이미지 2개 중 2개
    • Always be wary of plugging in suspected broken electronics into mains voltage of 120/220 VAC! IF SOMETHING SMOKES OR SMELLS BAD UNPLUG IT IMMEDIATELY!
    • Verify that the power adapter into the transformer brick itself is plugged in securely.
    • Check that the particular wall socket you are using is hot (plug in your phone charger and make sure it charges your phone).
    • Plug in the power supply to the wall outlet, but DO NOT plug it into the printer yet!
    • Check for a blue LED to come on to say the unit is powered up.
    댓글 쓰기
  2. UP! Plus 2 Power Supply Replacement, Test the Output Voltage: 2 단계, 이미지 1개 중 1개
    • Measure the output voltage of your power supply with a voltmeter or multimeter on the Volts DC setting.
    • To measure, insert the positive (red) probe into the middle of the connector while at the same time touching the outside metal jacket.
    • Make sure to make good contacts but not to short the two leads out by touching them together.
    • The multimeter should read anywhere between 18.5-20 Volts DC. This is the normal operating range of the power supply, if it outputs less than 16 Volts or more than 20 Volts your power supply is defective.
    • If you read correct voltage but your printer is still malfunctioning, continue with the guide.
    댓글 쓰기
  3. UP! Plus 2 Power Supply Replacement, Turn on the Printer: 3 단계, 이미지 1개 중 1개
    • Plug in the power connector and turn on the machine by depressing the rocker switch on the rear towards the line.
    • Does the red/green light on the front come on? If it does, your power supply is perfectly operational.
    • If the front lights do not come on at all this is generally an issue with the main board or the control board, which, in any case should be handled by the professionals who sell the printer. At this point you need to send in your printer for service. Sorry!
    댓글 쓰기
결론
Hopefully this guide helped you diagnose some of the issues that you might be experiencing with your printer.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
valerie boyer
회원 가입일: 10/12/14
508 평판
안내서 4개를 작성함
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014 회원
CPSU-MANESS-F14S14G31
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 23
전체 시간: 1,707
