주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
UTStarcom CDM8945vw Keyboard Replacement
필요한 것
  1. UTStarcom CDM8945vw Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  2. UTStarcom CDM8945vw Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery.
  3. UTStarcom CDM8945vw Keyboard Replacement, Antenna: 3 단계, 이미지 1개 중 1개
    • Identify the antenna. It is the extendable plastic component pictured here.
  4. UTStarcom CDM8945vw Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
  5. UTStarcom CDM8945vw Keyboard Replacement: 5 단계, 이미지 2개 중 1개 UTStarcom CDM8945vw Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • The antenna should slide right out of the phone when finished.
  6. UTStarcom CDM8945vw Keyboard Replacement, Speaker: 6 단계, 이미지 1개 중 1개
    • Remove the small rubber grommet using the plastic opening tool.
  7. UTStarcom CDM8945vw Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove five screws using a Phillips #00 screwdriver.
  8. UTStarcom CDM8945vw Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
  9. UTStarcom CDM8945vw Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the back piece of the outer case.
  10. UTStarcom CDM8945vw Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  11. UTStarcom CDM8945vw Keyboard Replacement: 11 단계, 이미지 2개 중 1개 UTStarcom CDM8945vw Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  12. UTStarcom CDM8945vw Keyboard Replacement, Logic Board: 12 단계, 이미지 1개 중 1개
    • Detach the highlighted piece from the logic board using a plastic opening tool.
  13. UTStarcom CDM8945vw Keyboard Replacement: 13 단계, 이미지 2개 중 1개 UTStarcom CDM8945vw Keyboard Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
  14. UTStarcom CDM8945vw Keyboard Replacement, Keyboard: 14 단계, 이미지 1개 중 1개
    • Remove the keyboard.
결론
작성자
4다른 기여자 명과 함께
Bryon Hazlewood
회원 가입일: 10/03/12
1 평판
안내서 2개를 작성함
Cal Poly, Team 24-26, Regan Fall 2012 Cal Poly, Team 24-26, Regan Fall 2012 회원
CPSU-REGAN-F12S24G26
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 33
전체 시간: 454
