주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
UTStarcom CDM8945vw Speaker Replacement
필요한 것
  1. UTStarcom CDM8945vw Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
    댓글 쓰기
  2. UTStarcom CDM8945vw Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery.
    댓글 쓰기
  3. UTStarcom CDM8945vw Speaker Replacement, Antenna: 3 단계, 이미지 1개 중 1개
    • Identify the antenna. It is the extendable plastic component pictured here.
    댓글 쓰기
  4. UTStarcom CDM8945vw Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
    댓글 쓰기
  5. UTStarcom CDM8945vw Speaker Replacement: 5 단계, 이미지 2개 중 1개 UTStarcom CDM8945vw Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • The antenna should slide right out of the phone when finished.
    댓글 쓰기
  6. UTStarcom CDM8945vw Speaker Replacement, Speaker: 6 단계, 이미지 1개 중 1개
    • Remove the small rubber grommet using the plastic opening tool.
    댓글 쓰기
  7. UTStarcom CDM8945vw Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Remove five screws using a Phillips #00 screwdriver.
    댓글 쓰기
  8. UTStarcom CDM8945vw Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
    댓글 쓰기
  9. UTStarcom CDM8945vw Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the back piece of the outer case.
    댓글 쓰기
  10. UTStarcom CDM8945vw Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    댓글 쓰기
  11. UTStarcom CDM8945vw Speaker Replacement: 11 단계, 이미지 2개 중 1개 UTStarcom CDM8945vw Speaker Replacement: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Eli
회원 가입일: 09/27/12
1 평판
안내서 2개를 작성함
Cal Poly, Team 24-26, Regan Fall 2012 Cal Poly, Team 24-26, Regan Fall 2012 회원
CPSU-REGAN-F12S24G26
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 27
전체 시간: 601
