주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ukulele String Replacement
필요한 것
  1. Ukulele String Replacement, Ukulele String Replacement: 1 단계, 이미지 1개 중 1개
    • Prepare by gathering all of the things you'll need: your ukulele, the new string, a pair or scissors, a sharpened pencil, a cloth, a string winder (optional), and a tuner or tuning app. Make sure you purchase the right sized strings.
    • Remove the old string by untying it from the bridge.
    • Unwind the string with its tuning peg.
    댓글 쓰기
  2. Ukulele String Replacement: 2 단계, 이미지 1개 중 1개
    • Clean the ukulele with a paper towel or cloth. Make sure to clean around the bridge and the tuners.
    댓글 쓰기
  3. Ukulele String Replacement: 3 단계, 이미지 1개 중 1개
    • The next step is to smooth run the strings. Use a sharpened pencil to add a little graphite to the indent where the string will lie. This helps the string slide smoothly through the slot.
    댓글 쓰기
  4. Ukulele String Replacement: 4 단계, 이미지 3개 중 1개 Ukulele String Replacement: 4 단계, 이미지 3개 중 2개 Ukulele String Replacement: 4 단계, 이미지 3개 중 3개
    • Tie-up the string to the bride of the Ukulele. Begin by sliding one end of the string through the holes on the bridge. Then wrap it around itself, as shown in the image. Make sure that it is snug against the bridge.
    • With the excess string, wrap it under the string once, and then twice. This will prevent the string from slipping.
    • Finally, to make it anchored, pull the string tightly into place.
    댓글 쓰기
  5. Ukulele String Replacement: 5 단계, 이미지 3개 중 1개 Ukulele String Replacement: 5 단계, 이미지 3개 중 2개 Ukulele String Replacement: 5 단계, 이미지 3개 중 3개
    • Put the end of the string through the hole in the tuning peg, and tightly wrap the string around the peg three times.
    • If it is wrapped more than three times, it may interfere with tuning, and less than three times could make it less secure.
    • Next, turn the tuning peg until there is tension in the string. This process can be sped up by using a string winder. Then snip off the excess string with a scissors.
    댓글 쓰기
  6. Ukulele String Replacement: 6 단계, 이미지 1개 중 1개
    • The final step is to tune your ukulele. Although this can be done by ear, you may find it easier to use a tuner or a tuning app.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bekah Klemp
회원 가입일: 09/19/18
154 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 42
전체 시간: 1,645
