주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Unbranded UB-15MS10 Battery Replacement
필요한 것
    1. Unbranded UB-15MS10 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use an opening tool to pry off the lid of the memory card compartment.
      댓글 쓰기
    2. Unbranded UB-15MS10 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
      댓글 쓰기
    3. Unbranded UB-15MS10 Battery Replacement: 3 단계, 이미지 2개 중 1개 Unbranded UB-15MS10 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Insert opening tools to partially pry open the cover.
      댓글 쓰기
    4. Unbranded UB-15MS10 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
      댓글 쓰기
    5. Unbranded UB-15MS10 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the tape that is holding the battery in place.
      댓글 쓰기
    6. Unbranded UB-15MS10 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Cut the wires connecting the battery to the device using a pair of wire cutters.
      댓글 쓰기
    7. Unbranded UB-15MS10 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Carefully remove the battery, making sure that all wires are disconnected.
      댓글 쓰기
    8. Unbranded UB-15MS10 Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Splice the new battery with the red, white, and black wires connected to the motherboard.
      댓글 쓰기
결론
To reassemble your device, follow directions 1-7 in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Evan Peterson
회원 가입일: 03/08/17
338 평판
안내서 2개를 작성함
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 UMass Dartmouth, Team S5-G5, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G5
3 회원들
안내서 4개를 작성함
1가이드 댓글
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 32
전체 시간: 2,911
