주요 콘텐츠로 건너뛰기
Understanding the brew unit in a fully automatic coffee machine
필요한 것
  1. Understanding the brew unit in a fully automatic coffee machine, Jura Impressa Type C E F opening procedure: 1 단계, 이미지 1개 중 1개
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Understanding the brew unit in a fully automatic coffee machine: 2 단계, 이미지 3개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 2 단계, 이미지 3개 중 2개 Understanding the brew unit in a fully automatic coffee machine: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Understanding the brew unit in a fully automatic coffee machine, Remove Jura Brew unit: 3 단계, 이미지 1개 중 1개
    • Slide the coffee funnel up and lift it out. It often sits very tight and you have to pull hard until it becomes free.
    • It is often firmly locked in place, it loosens if you wiggle it back and forth a little. It can also be fastened with a screw.
  4. Understanding the brew unit in a fully automatic coffee machine: 4 단계, 이미지 2개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 4 단계, 이미지 2개 중 2개
    • Remove the Torx T15 screw from the water inlet.
    • Lift the water inlet and bend it to the side. The hose can remain connected.
  5. Understanding the brew unit in a fully automatic coffee machine: 5 단계, 이미지 2개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 5 단계, 이미지 2개 중 2개
    • Pull out the clamp on the pressure hose between the steam valve and the brew unit.
    • Remove the pressure hose.
  6. Understanding the brew unit in a fully automatic coffee machine: 6 단계, 이미지 2개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 6 단계, 이미지 2개 중 2개
    • The brew unit is mounted from the motor side with two Torx T20 screws to the left and right of the motor connection, these are located deep on the inside.
    • Remove the right screw
    • Remove the left screw
  7. Understanding the brew unit in a fully automatic coffee machine: 7 단계, 이미지 2개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 7 단계, 이미지 2개 중 2개
    • The brew unit moves up and down in a slide driven by an elongated rack. There are four Torx T10 screws on the slide. The top left screw must remain attached.
    • The screw on the top left must remain.
    • Remove the screw on the bottom left
    • remove the screw on the bottom right and the one in the middle right
  8. Understanding the brew unit in a fully automatic coffee machine: 8 단계, 이미지 1개 중 1개
    • Now the brew unitis free. Tilt it to the bottom but pay attention to the pressure hose. It must be led through an opening. Then push the brew group slightly downward to lift it out of the unit.
    • For further disassembly of the brew unit use this manual JURA Brewgroup Disassembly
  9. Understanding the brew unit in a fully automatic coffee machine, Introduction to the Brew Unit: 9 단계, 이미지 1개 중 1개
    • In the picture, you'll see the brew unit. Some manufacturers also call it central unit or main unit - basically the equivalent of the CPU in a computer.
    • When the gear wheel is at the extreme end of the thread, this is referred to as the zero position, i.e. the position in which the brewing chamber is open.
  10. Understanding the brew unit in a fully automatic coffee machine: 10 단계, 이미지 3개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 10 단계, 이미지 3개 중 2개 Understanding the brew unit in a fully automatic coffee machine: 10 단계, 이미지 3개 중 3개
    • The ground coffee powder is fed into the brewing unit from here.
    • You can see how the lid of the powder container slowly closes the more we turn the gear wheel downwards over the thread.
  11. Understanding the brew unit in a fully automatic coffee machine: 11 단계, 이미지 3개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 11 단계, 이미지 3개 중 2개 Understanding the brew unit in a fully automatic coffee machine: 11 단계, 이미지 3개 중 3개
    • At the same time, the piston on the other side of the brewing unit is compressed.
    • The water is now being added where the finger is pointing in the second picture in this step.
    • And the third picture shows where the coffee will come out when it's ready.
  12. Understanding the brew unit in a fully automatic coffee machine: 12 단계, 이미지 2개 중 1개 Understanding the brew unit in a fully automatic coffee machine: 12 단계, 이미지 2개 중 2개
    • The piston then goes up again, i.e. the gear wheel turns back towards the zero position via the thread.
    • At the point where the finger is located in the picture, the coffee cake is then scraped outwards and ejected into the bowl.
    • The closer the cogwheel gets to the zero position, the more the lid of the powder container opens again until it is finally completely open when the zero position is reached again.
    • The machine is now ready for the next coffee.
  13. Understanding the brew unit in a fully automatic coffee machine, Importance of the Brew Unit: 13 단계, 이미지 1개 중 1개
    • The significance of the Brew Unit in the coffee-making process of a fully automatic machine is vital. It's extracting the flavors and aromas from the coffee grounds to create a perfect cup of coffee.
    • The valve of a brew unit is a common cause for a coffee machine to leak, learn about replacing it here: Saeco Talea/Odea Brew Unit SBS Valve Replacement.
    • Remember that any repairs or maintenance performed on your coffee fully automatic machine are at your own risk and responsibility. Always exercise caution. If you feel you need assistance, explore the option of visiting a Repair Café in your area. The experts there can provide guidance on repairing your coffee machine, including the Brew Unit.
결론
Sandra Hiller
회원 가입일: 10/17/16
26,927 평판
안내서 8개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,639개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 89
전체 시간: 1,534
