주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Uniden TCX905 Home Button Replacement
필요한 것
  1. Uniden TCX905 Home Button Replacement, Battery Cover: 1 단계, 이미지 2개 중 1개 Uniden TCX905 Home Button Replacement, Battery Cover: 1 단계, 이미지 2개 중 2개
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
    댓글 쓰기
  2. Uniden TCX905 Home Button Replacement, Battery Pack: 2 단계, 이미지 2개 중 1개 Uniden TCX905 Home Button Replacement, Battery Pack: 2 단계, 이미지 2개 중 2개
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
    댓글 쓰기
  3. Uniden TCX905 Home Button Replacement, Back Shell: 3 단계, 이미지 2개 중 1개 Uniden TCX905 Home Button Replacement, Back Shell: 3 단계, 이미지 2개 중 2개
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
    댓글 쓰기
  4. Uniden TCX905 Home Button Replacement: 4 단계, 이미지 3개 중 1개 Uniden TCX905 Home Button Replacement: 4 단계, 이미지 3개 중 2개 Uniden TCX905 Home Button Replacement: 4 단계, 이미지 3개 중 3개
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
    댓글 쓰기
  5. Uniden TCX905 Home Button Replacement: 5 단계, 이미지 3개 중 1개 Uniden TCX905 Home Button Replacement: 5 단계, 이미지 3개 중 2개 Uniden TCX905 Home Button Replacement: 5 단계, 이미지 3개 중 3개
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
    댓글 쓰기
  6. Uniden TCX905 Home Button Replacement, Circuit Board: 6 단계, 이미지 2개 중 1개 Uniden TCX905 Home Button Replacement, Circuit Board: 6 단계, 이미지 2개 중 2개
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
    댓글 쓰기
  7. Uniden TCX905 Home Button Replacement: 7 단계, 이미지 3개 중 1개 Uniden TCX905 Home Button Replacement: 7 단계, 이미지 3개 중 2개 Uniden TCX905 Home Button Replacement: 7 단계, 이미지 3개 중 3개
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
    댓글 쓰기
  8. Uniden TCX905 Home Button Replacement, Home Button: 8 단계, 이미지 3개 중 1개 Uniden TCX905 Home Button Replacement, Home Button: 8 단계, 이미지 3개 중 2개 Uniden TCX905 Home Button Replacement, Home Button: 8 단계, 이미지 3개 중 3개
    • Remove the white plastic sheet covering the silicon button pad
    • Remove the silicon button pad to access the home button and spring
    • Note: Be mindful that the spring is small and sensitive and can be lost easily if not cautious
    댓글 쓰기
  9. Uniden TCX905 Home Button Replacement: 9 단계, 이미지 2개 중 1개 Uniden TCX905 Home Button Replacement: 9 단계, 이미지 2개 중 2개
    • Once the silicon button pad is removed, remove the spring from home button
    • Finally, remove the home button from its setting in the front shell of the phone
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Gary Pence
회원 가입일: 03/26/14
807 평판
안내서 8개를 작성함
Clemson, Team 1-1, Benson Spring 2014 Clemson, Team 1-1, Benson Spring 2014 회원
CLEM-BENSON-S14S1G1
3 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 28
전체 시간: 921
