주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Using the 3DS's Safe Mode
    1. Using the 3DS's Safe Mode, Booting safe mode: 1 단계, 이미지 1개 중 1개
      • Ensure the console is powered off
      • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
      • Keep these buttons held down until the console boots in the next step
      • While still holding the other buttons, press the power button
      댓글 쓰기
    2. Using the 3DS's Safe Mode, Updating the System: 2 단계, 이미지 3개 중 1개 Using the 3DS's Safe Mode, Updating the System: 2 단계, 이미지 3개 중 2개 Using the 3DS's Safe Mode, Updating the System: 2 단계, 이미지 3개 중 3개
      • You should boot into a "system update" screen. Click OK and accept the prompts
      • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
      댓글 쓰기
    3. Using the 3DS's Safe Mode: 3 단계, 이미지 1개 중 1개
      • When the update finishes, the console will automatically turn off
      댓글 쓰기
결론
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
darth mango
회원 가입일: 03/13/23
3,808 평판
안내서 3개를 작성함
4가이드 댓글
Does this work on old family 3ds?
maxxy waxxy - 답글 공유
Works on every 3ds and 2ds model
darth mango - 답글 공유
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - 답글 공유
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
darth mango - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 119
지난 30일: 471
전체 시간: 16,131
