주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VENSTAR Taco Microphone Replacement Replacement
필요한 것
    1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: 1 단계, 이미지 3개 중 1개 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: 1 단계, 이미지 3개 중 2개 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: 1 단계, 이미지 3개 중 3개
      • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
      • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
      댓글 쓰기
    2. VENSTAR Taco Microphone Replacement Replacement: 2 단계, 이미지 2개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 2 단계, 이미지 2개 중 2개
      • Repeat the previous step on the opposite side to remove the other outer casing.
      댓글 쓰기
    3. VENSTAR Taco Microphone Replacement Replacement: 3 단계, 이미지 2개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Phillips #0 Screwdriver
      $5.49
      • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
      • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
      댓글 쓰기
    4. VENSTAR Taco Microphone Replacement Replacement: 4 단계, 이미지 2개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 4 단계, 이미지 2개 중 2개
      • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
      댓글 쓰기
    5. VENSTAR Taco Microphone Replacement Replacement: 5 단계, 이미지 2개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 5 단계, 이미지 2개 중 2개
      • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
      댓글 쓰기
    1. VENSTAR Taco Microphone Replacement Replacement, Logic Board Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the rubber covering from the buttons.
      댓글 쓰기
    2. VENSTAR Taco Microphone Replacement Replacement: 7 단계, 이미지 3개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 7 단계, 이미지 3개 중 2개 VENSTAR Taco Microphone Replacement Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the black fabric covering the logic board.
      댓글 쓰기
    3. VENSTAR Taco Microphone Replacement Replacement: 8 단계, 이미지 2개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 8 단계, 이미지 2개 중 2개
      • Move the battery out of the way of the connector.
      댓글 쓰기
    4. VENSTAR Taco Microphone Replacement Replacement: 9 단계, 이미지 2개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 9 단계, 이미지 2개 중 2개
      • Undo the connector of the flat white ribbon between the switches and the logic board.
      댓글 쓰기
    5. VENSTAR Taco Microphone Replacement Replacement: 10 단계, 이미지 1개 중 1개
      • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
      댓글 쓰기
    6. VENSTAR Taco Microphone Replacement Replacement: 11 단계, 이미지 3개 중 1개 VENSTAR Taco Microphone Replacement Replacement: 11 단계, 이미지 3개 중 2개 VENSTAR Taco Microphone Replacement Replacement: 11 단계, 이미지 3개 중 3개
      • Gently pull out the logic board.
      • Note that the battery and the logic board are connected and must be removed together.
      댓글 쓰기
    1. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: 12 단계, 이미지 2개 중 1개 VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: 12 단계, 이미지 2개 중 2개
      • Below the logic board, the small black microphone is resting within the case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kaylee Simms
회원 가입일: 01/30/16
310 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
전체 시간: 472
