주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Baby's Learning Laptop Mode Switch Replacement
필요한 것
    1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: 1 단계, 이미지 1개 중 1개
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      댓글 쓰기
    2. VTech Baby's Learning Laptop Mode Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery door.
      • Take out the batteries.
      댓글 쓰기
    3. VTech Baby's Learning Laptop Mode Switch Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      댓글 쓰기
    4. VTech Baby's Learning Laptop Mode Switch Replacement: 4 단계, 이미지 2개 중 1개 VTech Baby's Learning Laptop Mode Switch Replacement: 4 단계, 이미지 2개 중 2개
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      댓글 쓰기
    1. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 5 단계, 이미지 2개 중 1개 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: 5 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
      댓글 쓰기
    2. VTech Baby's Learning Laptop Mode Switch Replacement: 6 단계, 이미지 3개 중 1개 VTech Baby's Learning Laptop Mode Switch Replacement: 6 단계, 이미지 3개 중 2개 VTech Baby's Learning Laptop Mode Switch Replacement: 6 단계, 이미지 3개 중 3개
      • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
      • Lay the board down gently and out of the way.
      • Take care not to damage any of the wires or the board itself.
      댓글 쓰기
    3. VTech Baby's Learning Laptop Mode Switch Replacement: 7 단계, 이미지 1개 중 1개
      • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
      • Five 7.3mm
      • Two 6.0mm
      댓글 쓰기
    4. VTech Baby's Learning Laptop Mode Switch Replacement: 8 단계, 이미지 1개 중 1개
      • Once the screws have been removed, the mode switch assembly can be removed easily.
      • Take care not to misplace the spring indicated in the picture.
      • You need this spring to find a matching replacement if it is in anyway damaged.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Scott Parkinson
회원 가입일: 09/09/15
113 평판
안내서 1개를 작성함
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G2
4 회원들
안내서 63개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 843
