주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Baby's Learning Laptop Mouse Replacement
필요한 것
    1. VTech Baby's Learning Laptop Mouse Replacement, Battery and Rear Panel: 1 단계, 이미지 1개 중 1개
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      댓글 쓰기
    2. VTech Baby's Learning Laptop Mouse Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery door.
      • Take out the batteries.
      댓글 쓰기
    3. VTech Baby's Learning Laptop Mouse Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      댓글 쓰기
    4. VTech Baby's Learning Laptop Mouse Replacement: 4 단계, 이미지 2개 중 1개 VTech Baby's Learning Laptop Mouse Replacement: 4 단계, 이미지 2개 중 2개
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      댓글 쓰기
    1. VTech Baby's Learning Laptop Mouse Replacement, Mouse: 5 단계, 이미지 2개 중 1개 VTech Baby's Learning Laptop Mouse Replacement, Mouse: 5 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
      댓글 쓰기
    2. VTech Baby's Learning Laptop Mouse Replacement: 6 단계, 이미지 3개 중 1개 VTech Baby's Learning Laptop Mouse Replacement: 6 단계, 이미지 3개 중 2개 VTech Baby's Learning Laptop Mouse Replacement: 6 단계, 이미지 3개 중 3개
      • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
      • Lay the board down gently and out of the way.
      • Take care not to damage any of the wires or the board itself.
      댓글 쓰기
    3. VTech Baby's Learning Laptop Mouse Replacement: 7 단계, 이미지 3개 중 1개 VTech Baby's Learning Laptop Mouse Replacement: 7 단계, 이미지 3개 중 2개 VTech Baby's Learning Laptop Mouse Replacement: 7 단계, 이미지 3개 중 3개
      • Locate and remove the following screws:
      • Two 11.0mm Phillips #2.
      • Two 7.3mm Phillips #0.
      • Remove the top of the mouse which will separate from the under side once the screws are removed.
      • The metal connection near the yellow screws on the top left of the mouse assembly falls out very easily. Make sure to replace the metal connection with the prong pointing up. Otherwise, the mouse will not work correctly.
      댓글 쓰기
    4. VTech Baby's Learning Laptop Mouse Replacement: 8 단계, 이미지 2개 중 1개 VTech Baby's Learning Laptop Mouse Replacement: 8 단계, 이미지 2개 중 2개
      • Lift the springs up from the screw pegs with a plastic opening tool.
      • Remove the final part of the mouse.
      • Before reassembly, see the note on the previous step.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Justin Schanze
회원 가입일: 09/03/15
266 평판
안내서 1개를 작성함
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G2
4 회원들
안내서 57개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 45
전체 시간: 1,722
