주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech InnoTab 2 Camera Replacement
필요한 것
  1. VTech InnoTab 2 Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 VTech InnoTab 2 Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 VTech InnoTab 2 Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Camera Replacement, Back Panel: 2 단계, 이미지 3개 중 1개 VTech InnoTab 2 Camera Replacement, Back Panel: 2 단계, 이미지 3개 중 2개 VTech InnoTab 2 Camera Replacement, Back Panel: 2 단계, 이미지 3개 중 3개
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Camera Replacement: 3 단계, 이미지 3개 중 1개 VTech InnoTab 2 Camera Replacement: 3 단계, 이미지 3개 중 2개 VTech InnoTab 2 Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Camera Replacement: 4 단계, 이미지 2개 중 1개 VTech InnoTab 2 Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Camera Replacement: 5 단계, 이미지 2개 중 1개 VTech InnoTab 2 Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
  6. VTech InnoTab 2 Camera Replacement, Camera: 6 단계, 이미지 3개 중 1개 VTech InnoTab 2 Camera Replacement, Camera: 6 단계, 이미지 3개 중 2개 VTech InnoTab 2 Camera Replacement, Camera: 6 단계, 이미지 3개 중 3개
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection to the camera is located on top side of the devices motherboard.
    • Pulling the camera while the connection to the motherboard is still intact can cause damage to the circuit board.
    • Attach the replacement camera and lower the latch until a click sound can be heard.
결론
작성자
1다른 기여자 명과 함께
Roberto Valdes
회원 가입일: 10/18/17
302 평판
안내서 3개를 작성함
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G85
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 49
전체 시간: 592
