주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech InnoTab 2s Screen Replacement
필요한 것
    1. VTech InnoTab 2s Screen Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Turn your device to where the back panel is facing you.
      댓글 쓰기
    2. VTech InnoTab 2s Screen Replacement: 2 단계, 이미지 2개 중 1개 VTech InnoTab 2s Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the Leg all the way up and twist the bottom to remove.
      • Once the bottom part pops out the whole leg should just come off.
      • Remove any game cartridge from the device.
      댓글 쓰기
    3. VTech InnoTab 2s Screen Replacement: 3 단계, 이미지 3개 중 1개 VTech InnoTab 2s Screen Replacement: 3 단계, 이미지 3개 중 2개 VTech InnoTab 2s Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
      • These covers are made of hard plastic so they may be difficult to remove.
      • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
      댓글 쓰기
    4. VTech InnoTab 2s Screen Replacement: 4 단계, 이미지 2개 중 1개 VTech InnoTab 2s Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Remove all nine screws from the back of the device using a J0 bit.
      • Remove the small battery.
      댓글 쓰기
    5. VTech InnoTab 2s Screen Replacement: 5 단계, 이미지 2개 중 1개 VTech InnoTab 2s Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, detach the backplate from the front piece.
      • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
      • Once the backplate has been removed, you will have access to the circuit board.
      댓글 쓰기
    1. VTech InnoTab 2s Screen Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
      • First begin by removing the three cross-head screws using a J0 bit.
      댓글 쓰기
    2. VTech InnoTab 2s Screen Replacement: 7 단계, 이미지 1개 중 1개
      • First remove the ribbon cables. There are two highlighted by the red squares
      • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
      댓글 쓰기
    3. VTech InnoTab 2s Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
      댓글 쓰기
    4. VTech InnoTab 2s Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the board from the main assembly.
      • Be careful not to pull too hard so that the cables aren't broken.
      댓글 쓰기
    5. VTech InnoTab 2s Screen Replacement: 10 단계, 이미지 1개 중 1개
      • De-solder the points shown to fully remove the cables and free the board.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills.
      댓글 쓰기
    1. VTech InnoTab 2s Screen Replacement, Screen: 11 단계, 이미지 2개 중 1개 VTech InnoTab 2s Screen Replacement, Screen: 11 단계, 이미지 2개 중 2개
      • After removing the back plate and screws, all screws have been removed to separate the circuit board and wires from the front panel.
      • Remove the front panel from the device to expose the screen.
      댓글 쓰기
    2. VTech InnoTab 2s Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Using a heat gun, heat the glue that holds the screen to the rest of the device.
      • While heating, carefully pull screen from the device exposing the ribbon wire on the back of the screen, disconnect.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Esthevan Romeiro
회원 가입일: 10/06/16
261 평판
안내서 4개를 작성함
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 회원
USFT-LACY-F16S5G1
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 1,181
