주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech InnoTab Max Battery Replacement
필요한 것
    1. VTech InnoTab Max Battery Replacement, Cover: 1 단계, 이미지 3개 중 1개 VTech InnoTab Max Battery Replacement, Cover: 1 단계, 이미지 3개 중 2개 VTech InnoTab Max Battery Replacement, Cover: 1 단계, 이미지 3개 중 3개
      • Remove all screw caps from the back panel using a metal spudger.
      댓글 쓰기
    2. VTech InnoTab Max Battery Replacement: 2 단계, 이미지 3개 중 1개 VTech InnoTab Max Battery Replacement: 2 단계, 이미지 3개 중 2개 VTech InnoTab Max Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      댓글 쓰기
    3. VTech InnoTab Max Battery Replacement: 3 단계, 이미지 2개 중 1개 VTech InnoTab Max Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      댓글 쓰기
    4. VTech InnoTab Max Battery Replacement: 4 단계, 이미지 2개 중 1개 VTech InnoTab Max Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      댓글 쓰기
    1. VTech InnoTab Max Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
      댓글 쓰기
    2. VTech InnoTab Max Battery Replacement: 6 단계, 이미지 3개 중 1개 VTech InnoTab Max Battery Replacement: 6 단계, 이미지 3개 중 2개 VTech InnoTab Max Battery Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
      • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
      • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
      댓글 쓰기
    3. VTech InnoTab Max Battery Replacement: 7 단계, 이미지 3개 중 1개 VTech InnoTab Max Battery Replacement: 7 단계, 이미지 3개 중 2개 VTech InnoTab Max Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
      댓글 쓰기
    4. VTech InnoTab Max Battery Replacement: 8 단계, 이미지 1개 중 1개
      • The battery is now fully disconnected.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jacob Schioppo
회원 가입일: 02/15/17
594 평판
안내서 4개를 작성함
USF Tampa, Team S5-G5, Lacy Spring 2017 USF Tampa, Team S5-G5, Lacy Spring 2017 회원
USFT-LACY-S17S5G5
3 회원들
안내서 10개를 작성함
10가이드 댓글
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - 답글 공유
Where can we purchase a replacement battery
Frank Godon - 답글 공유
Where can we buy a replacement battery
Frank Godon - 답글 공유
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - 답글 공유
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 63
전체 시간: 15,871
