주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Kidizoom Camera Connect Shutter Button Replacement
필요한 것
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: 1 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: 1 단계, 이미지 2개 중 2개
      • Remove batteries and SD card before beginning disassembly!
      • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
      댓글 쓰기
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: 2 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect Shutter Button Replacement: 2 단계, 이미지 2개 중 2개
      • Remove all four (11mm) screws with the Philips #0 screwdriver.
      댓글 쓰기
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: 3 단계, 이미지 3개 중 1개 VTech Kidizoom Camera Connect Shutter Button Replacement: 3 단계, 이미지 3개 중 2개 VTech Kidizoom Camera Connect Shutter Button Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the two battery cartridges located on the underside of the camera.
      • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
      댓글 쓰기
    4. VTech Kidizoom Camera Connect Shutter Button Replacement: 4 단계, 이미지 1개 중 1개
      • Beware of the two black viewfinder lens falling out as you pry open the device!
      • The device should now be open and ready for further repair and/or replacement parts.
      댓글 쓰기
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: 5 단계, 이미지 1개 중 1개
      • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
      댓글 쓰기
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: 6 단계, 이미지 1개 중 1개
      • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
      댓글 쓰기
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: 7 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect Shutter Button Replacement: 7 단계, 이미지 2개 중 2개
      • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Justin Sanchez
회원 가입일: 02/08/16
544 평판
안내서 4개를 작성함
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 37
전체 시간: 1,608
