주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech MobiGo Touch Learning System Screen Replacement
필요한 것
    1. VTech MobiGo Touch Learning System Screen Replacement, Case: 1 단계, 이미지 1개 중 1개
      • Remove the battery covers and the four batteries.
      댓글 쓰기
    2. VTech MobiGo Touch Learning System Screen Replacement: 2 단계, 이미지 2개 중 1개 VTech MobiGo Touch Learning System Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      댓글 쓰기
    3. VTech MobiGo Touch Learning System Screen Replacement: 3 단계, 이미지 2개 중 1개 VTech MobiGo Touch Learning System Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      댓글 쓰기
    1. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 4 단계, 이미지 1개 중 1개
      • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
      댓글 쓰기
    2. VTech MobiGo Touch Learning System Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the three "L" shaped brackets and the spring.
      댓글 쓰기
    3. VTech MobiGo Touch Learning System Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
      댓글 쓰기
    4. VTech MobiGo Touch Learning System Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Separate the front and back of the case.
      • Use a plastic opening tool if necessary.
      댓글 쓰기
    1. VTech MobiGo Touch Learning System Screen Replacement, Screen: 8 단계, 이미지 1개 중 1개
      • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
      댓글 쓰기
    2. VTech MobiGo Touch Learning System Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the black tape
      댓글 쓰기
    3. VTech MobiGo Touch Learning System Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the circuit board from the back of the screen.
      • The circuit board has double sided tape on the back side holding it to the screen.
      댓글 쓰기
    4. VTech MobiGo Touch Learning System Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
      댓글 쓰기
    5. VTech MobiGo Touch Learning System Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Resolder the new screens ribbon cable on the the circuit board.
      • Always be careful when soldering.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Daniel Kresge
회원 가입일: 09/01/15
409 평판
안내서 4개를 작성함
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S8G3
3 회원들
안내서 49개를 작성함
1가이드 댓글
mine i droped a rock on so i don’t get it
Jesse Eagan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 50
전체 시간: 1,294
