주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Safe And Sound DM221 Buttons Replacement
필요한 것
    1. VTech Safe And Sound DM221 Buttons Replacement, Buttons: 1 단계, 이미지 1개 중 1개
      • Remove the battery cover by sliding it down.
      댓글 쓰기
    2. VTech Safe And Sound DM221 Buttons Replacement: 2 단계, 이미지 1개 중 1개
      • Firmly grasp the battery and pull to disconnect the battery from its connector.
      댓글 쓰기
    3. VTech Safe And Sound DM221 Buttons Replacement: 3 단계, 이미지 1개 중 1개
      • Using a Phillips #00 screwdriver, unscrew the two 5.0 mm screws located at the bottom of the monitor inside of the device.
      댓글 쓰기
    4. VTech Safe And Sound DM221 Buttons Replacement: 4 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, pry apart the front part of the device from the back. There are many access points, but the best spot to insert the spudger is around the "TALK" button.
      • Avoid using the metal spudger. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      댓글 쓰기
    5. VTech Safe And Sound DM221 Buttons Replacement: 5 단계, 이미지 2개 중 1개 VTech Safe And Sound DM221 Buttons Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the buttons from the front part of the device.
      • Tip: The buttons on the front of the device (“POWER,” “SELECT,” “MENU,” “VOLUME”) are all connected as one unit. Pull them out carefully.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Krystal
회원 가입일: 10/01/15
600 평판
안내서 5개를 작성함
USF Tampa, Team 1-5, Leahy Fall 2015 USF Tampa, Team 1-5, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 626
