주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Safe and Sound DM111-2 Baby Unit Motherboard replacement Guide
필요한 것
    1. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Baby Unit Motherboard replacement Guide: 1 단계, 이미지 1개 중 1개
      • Along the back of unit there are two 4mm philips head screws towards the bottom of the unit. Start by removing these two screws using your PH0 screwdriver.
      댓글 쓰기
    2. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 2 단계, 이미지 2개 중 1개 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 2 단계, 이미지 2개 중 2개
      • Using the plastic spudger gently pry along the middle of the 2 sections of the plastic housing in order to release plastic latches on the inside of the housing.
      • Unlike the parent unit there are no wires across the two housing pieces, so once the latches are undone simply pull it apart without worry of disconnecting anything.
      댓글 쓰기
    3. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 3 단계, 이미지 2개 중 1개 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 3 단계, 이미지 2개 중 2개
      • Once apart the motherboard will be exposed with two 4mm phillips head screws near the top and 4 wires leading leading to a circuit board hidden under the motherboard.
      • Remove the two screws near the top of the motherboard.
      댓글 쓰기
    4. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: 4 단계, 이미지 2개 중 1개 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: 4 단계, 이미지 2개 중 2개
      • Remove the strip of adhesive tape located under the motherboard.
      • Gently lift the motherboard to expose the inner components.
      • Use a spudger to scrape away the adhesive and foam connecting the microphone.
      • Unscrew the 4mm phillips head screw holding the microphone in place.
      댓글 쓰기
    5. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 5 단계, 이미지 3개 중 1개 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 5 단계, 이미지 3개 중 2개 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Desoldering Pump
      $3.99
      • Before de-soldering, check to see no scorching or broken connections appear on the wires, power supply jack or antenna.
      • De-solder the connections from the motherboard using a soldering iron and a solder sucker.
      • De-solder the connections to the microphone, located on the bottom left of the mother board.
      • De-solder the 4 wires connecting the LED board to the motherboard.
      • De-solder the antenna's solder joint, located above the microphone wire connection.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jean Carlos
회원 가입일: 08/31/15
201 평판
안내서 2개를 작성함
USF Tampa, Team 6-3, Remmell Fall 2015 USF Tampa, Team 6-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 33
전체 시간: 1,329
