주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Write and Learn Creative Center Magnetic Screen Replacement
필요한 것
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
      • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
      댓글 쓰기
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: 2 단계, 이미지 1개 중 1개
      • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
      • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
      댓글 쓰기
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 3 단계, 이미지 2개 중 1개 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 3 단계, 이미지 2개 중 2개
      • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
      댓글 쓰기
    2. VTech Write and Learn Creative Center Magnetic Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Gently push the edges of the screen to remove it from the front case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Philip Zietkowski
회원 가입일: 03/25/16
345 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 회원
UMASSD-MILES-S16S1G2
3 회원들
안내서 48개를 작성함
2가이드 댓글
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - 답글 공유
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 33
전체 시간: 1,898
