주요 콘텐츠로 건너뛰기
VanMoof S3 Bell Button Replacement
필요한 것
  1. VanMoof S3 Bell Button Replacement, Screwing around.: 1 단계, 이미지 3개 중 1개 VanMoof S3 Bell Button Replacement, Screwing around.: 1 단계, 이미지 3개 중 2개 VanMoof S3 Bell Button Replacement, Screwing around.: 1 단계, 이미지 3개 중 3개
    • In my case the button was glued additionally. Cut around it to make it loose.
    • Use the 2mm hex screwdriver and remove the tiny screw on the side of the bell housing.
    • Use the pliers to unscrew the button. Screw to the left.
    • You can't break what is already broken. It should come off easily, so keep cool. Although, in my case, the button top broke off.
    • Don't forget to turn off the bike!
  2. VanMoof S3 Bell Button Replacement, Hexen: 2 단계, 이미지 2개 중 1개 VanMoof S3 Bell Button Replacement, Hexen: 2 단계, 이미지 2개 중 2개
    • Loosen the 5mm screw located below the button.
    • If you unscrew both, you can try blowing compressed air through the holes. This may or may not solve the problem.
    • This screw holds the break/button part on the wheel. Later, you will need to pull it off. As you can see, the cable goes through the rubber grips.
  3. VanMoof S3 Bell Button Replacement, Handle this: 3 단계, 이미지 3개 중 1개 VanMoof S3 Bell Button Replacement, Handle this: 3 단계, 이미지 3개 중 2개 VanMoof S3 Bell Button Replacement, Handle this: 3 단계, 이미지 3개 중 3개
    • Use the wrench and the cloth to remove the handle grips. The cable goes through it - then through the handlebar.
    • At his point you could just solder a new button to the old cable and be done.
    • If you don't want to wait for replacement part from VanMoof - these buttons on Amazon have the exact dimensions and are waterproof,
  4. VanMoof S3 Bell Button Replacement, the goo: 4 단계, 이미지 3개 중 1개 VanMoof S3 Bell Button Replacement, the goo: 4 단계, 이미지 3개 중 2개 VanMoof S3 Bell Button Replacement, the goo: 4 단계, 이미지 3개 중 3개
    • Get rid of the old button. When you cut it off, the bike can turn on. So: Turn it off.
    • Clean the handlebar of the goo. In my case it was wet inside.
  5. VanMoof S3 Bell Button Replacement, the thread: 5 단계, 이미지 2개 중 1개 VanMoof S3 Bell Button Replacement, the thread: 5 단계, 이미지 2개 중 2개
    • Push the the whole break/bell part over the handle. And thread the new cable through the hole, as you can see in the picture.
    • Tie the old cable and the end of the new one together.
  6. VanMoof S3 Bell Button Replacement, red or black?: 6 단계, 이미지 3개 중 1개 VanMoof S3 Bell Button Replacement, red or black?: 6 단계, 이미지 3개 중 2개 VanMoof S3 Bell Button Replacement, red or black?: 6 단계, 이미지 3개 중 3개
    • Unscrew the handlebar with the 5mm hex wrench.
    • Remove the rubber cap located underside the handlebar. Remember where you put it.
    • In my case the bell button was the unmarked cable. Start to pull it to get the new one through. Good luck!
  7. VanMoof S3 Bell Button Replacement, second try: 7 단계, 이미지 3개 중 1개 VanMoof S3 Bell Button Replacement, second try: 7 단계, 이미지 3개 중 2개 VanMoof S3 Bell Button Replacement, second try: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • If you are unlucky and loose the cable inside. Try to fix it to a wire.
    • You can also try to use the wire, to block the path through that hole in the wheel, and push just the cable. It should than bend and appear in the hole.
    • Use the hole and the tweezers to get the cable halfway through.
    • Connect the cables. And try the bell.
  8. VanMoof S3 Bell Button Replacement, assembly: 8 단계, 이미지 3개 중 1개 VanMoof S3 Bell Button Replacement, assembly: 8 단계, 이미지 3개 중 2개 VanMoof S3 Bell Button Replacement, assembly: 8 단계, 이미지 3개 중 3개
    • Put everything back together. Use some proper electrical tape to get the cable in place.
    • Before you put the tiny 2mm hex screw should, check if hits the flat part of the side of the button.
    • I removed the old glue with the tweezers and applied some fresh hot glue.
  9. VanMoof S3 Bell Button Replacement, final report: 9 단계, 이미지 3개 중 1개 VanMoof S3 Bell Button Replacement, final report: 9 단계, 이미지 3개 중 2개 VanMoof S3 Bell Button Replacement, final report: 9 단계, 이미지 3개 중 3개
    • That was not so hard at all. It took me 40 minutes. But to for the future i come prepared. I designed this protection caps for the buttons. You can get them 3d printed on my ebay.
    • Link to Ebay NO if will not upload this to Thingiverse.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Prokrastinator
회원 가입일: 08/18/17
386 평판
안내서 2개를 작성함
8가이드 댓글
The link to the Ebay page seems broken
peter - 답글
Vielen Dank für diese ausführliche Anleitung. Das hat mir wirklich sehr geholfen beim E41!
joergjhansen - 답글
Moin hätte eine Frage welche Größe hat die Mini Schraube an der Seite vom Knopf hab sie verloren Weis jetzt nicht ob m2 oder 2.5 würde mich über eine Antwort freuen
IngoImTwingo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 56
지난 30일: 255
전체 시간: 26,724
