주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vent Panel Disassembly
필요한 것
  1. Vent Panel Disassembly, Remove Service Panel Screws: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
    댓글 쓰기
  2. Vent Panel Disassembly, Dislodge Service Panel: 2 단계, 이미지 3개 중 1개 Vent Panel Disassembly, Dislodge Service Panel: 2 단계, 이미지 3개 중 2개 Vent Panel Disassembly, Dislodge Service Panel: 2 단계, 이미지 3개 중 3개
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
    댓글 쓰기
  3. Vent Panel Disassembly, Remove screw covers: 3 단계, 이미지 1개 중 1개
    • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
    댓글 쓰기
  4. Vent Panel Disassembly, Unfasten vent panel: 4 단계, 이미지 2개 중 1개 Vent Panel Disassembly, Unfasten vent panel: 4 단계, 이미지 2개 중 2개
    • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
    • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
    댓글 쓰기
  5. Vent Panel Disassembly, Remove vent panel: 5 단계, 이미지 2개 중 1개 Vent Panel Disassembly, Remove vent panel: 5 단계, 이미지 2개 중 2개
    • Remove the vent panel by lifting directly up to dislodge it from the brace.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
iodyne
회원 가입일: 01/01/22
462 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 29
전체 시간: 387
