주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Verizon Ellipsis 7 Battery Replacement
필요한 것
    1. Verizon Ellipsis 7 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Verizon Ellipsis 7 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Verizon Ellipsis 7 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Power down device by holding down the power button until the screen goes black.
      • Remove the SIM card from the device to prevent damage.
      • To remove the SIM card, open the SIM card cover on the side of the device.
      • Push SIM card in and then pull out after hearing a click.
      댓글 쓰기
    2. Verizon Ellipsis 7 Battery Replacement: 2 단계, 이미지 2개 중 1개 Verizon Ellipsis 7 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Take off the back panel.
      • Pry open the back cover carefully with a plastic opening tool.
      • Use the opening tool to disconnect the cover completely. Do not attempt to pull the back cover off with your hands.
      • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
      댓글 쓰기
    3. Verizon Ellipsis 7 Battery Replacement: 3 단계, 이미지 3개 중 1개 Verizon Ellipsis 7 Battery Replacement: 3 단계, 이미지 3개 중 2개 Verizon Ellipsis 7 Battery Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
      • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
      • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
      • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Scott Mangin
회원 가입일: 01/24/17
609 평판
안내서 2개를 작성함
Cal Poly, Team 13-5, Banghart Winter 2017 Cal Poly, Team 13-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G5
4 회원들
안내서 4개를 작성함
8가이드 댓글
so much for the charging port. You didn’t mention the battery. ?
good1946scout - 답글 공유
Well….ok…..but were we here for removing the charging port? Ha ha….I think not. So how about we lift out the battery and unplug it instead. Takes a bit of effort , it seems. That sucker is stuck down pretty good with some really good double sided tape. Lift carefully. I pried it up with the same plastic case tool I used to remove the back cover. The same tool also helped me remove the battery plug.
David Shaw - 답글 공유
First time on Ifixit and they leave me two steps from the goal; not much of a confidence-builder for this site!
Groove - 답글 공유
WTH? Replacing the battery?
kaycha12 - 답글 공유
Look at the stats..
Why suddenly are so many units failing at or about the same time? I'm not a conspirist but,
Don't you think it's a strange coincidence?
Kermit Allison - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 57
전체 시간: 30,653
