주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Verizon Ellipsis 8 Battery Replacement
필요한 것
  1. Verizon Ellipsis 8 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
    댓글 쓰기
  2. Verizon Ellipsis 8 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
    댓글 쓰기
  3. Verizon Ellipsis 8 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
    댓글 쓰기
  4. Verizon Ellipsis 8 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Lift and remove the battery from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Jack
회원 가입일: 02/06/19
610 평판
안내서 3개를 작성함
UC Davis, Team S18-G6, Lore Winter 2019 UC Davis, Team S18-G6, Lore Winter 2019 회원
UCD-LORE-W19S18G6
3 회원들
안내서 3개를 작성함
3가이드 댓글
Thanks! Easy to follow because of the pictures.
Siegfried Harrison Ph.D. - 답글 공유
These instructions do not apply to the Verizon Ellipsis 8, QTASUN1. The G3 LTE unit requires that you remove the top end that covers the camera lens by popping the edge fasteners along the seam across the back with the spudger, carefully and then sliding the end (that covers the camera lens) off the top of the tablet. At that point three tiny Allen screws will become exposed. Remove the tiny screws and put them on a piece of tape! Make sure the micro memory card and sim card are removed! Using the spudger ( or a very thin knife edge) pop the bottom covering snaps backwards until you can slide the back downward to expose the battery. At that point it is the same as the description for battery replacement. Be very careful about loosing the three tiny, tiny, tainy flat head allen screws that hold the back on the tablet. Take your time and be methodical. If an 80 year old can do it, so can you!
James V Redding - 답글 공유
Can you tell me what size the screws are that hold in the battery, I know that the thread size is 0.1 mm but I have been trying to find replacement screws and can't find them anywhere so I have to custom order them and need more information on them? Any assistance you could give me would be greatly appreciated. jwooten_el@yahoo.com
James Wooten - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 82
전체 시간: 11,470
