주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vernee Thor Disassembly
필요한 것
동영상 개요
  1. Vernee Thor Disassembly, Prepare your phone: 1 단계, 이미지 1개 중 1개
    • Before you proceed, discharge your battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Shut down your phone.
    • Set the phone down on a soft surface with space to store removed parts safely.
    • Unclip and remove the rear cover,
    • Remove any SIM/MicroSD cards.
    • Unscrew 12 black screws. A magnet is helpful for storing them. Try a fridge magnet face down.
    • Put adhesive tape over the volume and power buttons so they don't get lost,
    댓글 쓰기
  2. Vernee Thor Disassembly, Remove the frame: 2 단계, 이미지 1개 중 1개
    • Use a pick or your thumbnail around the display bezel to separate the frame from the phone.
    • Set aside the frame being careful not to lose the volume and power buttons.
    • If the metal battery shield did not come off with the frame, lift it off and put it with the frame.
    댓글 쓰기
  3. Vernee Thor Disassembly, Disconnect the battery: 3 단계, 이미지 1개 중 1개
    • Gently pry the battery plug up as shown.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
    • Bend the cable up so the plug can't touch the board.
    댓글 쓰기
  4. Vernee Thor Disassembly, Remove the battery: 4 단계, 이미지 1개 중 1개
    • Unpick the white tabs from the top of the battery and pull gently and slowly as shown. Be careful not to snag the tapes. If both tapes come out cleanly the battery will be free. Hold the battery down with your other hand.
    • If the white tapes snap under the battery, gently pry the long edges of the battery away from the metal midframe with a flat plastic pry tool such as a bank card.
    • Be careful not to damage the flat cable underneath the battery!
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tim
회원 가입일: 08/31/10
1,526 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 32
전체 시간: 2,218
