주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vicks FilterFree Plus Touchpad Motherboard Replacement
필요한 것
    1. Vicks FilterFree Plus Touchpad Motherboard Replacement, Tank Cap: 1 단계, 이미지 1개 중 1개
      • Ensure the device is clear of water before disassembling.
      • Orient the device so the nozzle is facing the ceiling.
      • Twist off the primary water holding cap.
      댓글 쓰기
    2. Vicks FilterFree Plus Touchpad Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Vicks FilterFree Plus Touchpad Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Place the device upside down so that the tank cap is facing you.
      • Use your hands to twist the tank cap and remove it from the device.
      댓글 쓰기
    1. Vicks FilterFree Plus Touchpad Motherboard Replacement, Touchpad Motherboard: 3 단계, 이미지 2개 중 1개 Vicks FilterFree Plus Touchpad Motherboard Replacement, Touchpad Motherboard: 3 단계, 이미지 2개 중 2개
      • Remove the three screws from the base of the device using a T20 Torx screwdriver.
      • Remove the base of the humidifier to access the components.
      댓글 쓰기
    2. Vicks FilterFree Plus Touchpad Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Vicks FilterFree Plus Touchpad Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
      댓글 쓰기
    3. Vicks FilterFree Plus Touchpad Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Vicks FilterFree Plus Touchpad Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • When both wires are followed, one connects to the central hub and the other connects to another smaller circuit board. In order to get to the smaller circuit board, the central one needs to be unscrewed.
      • Remove both screws using a Phillips #1 screwdriver.
      • Lift up the central circuit board.
      댓글 쓰기
    4. Vicks FilterFree Plus Touchpad Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Vicks FilterFree Plus Touchpad Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Vicks FilterFree Plus Touchpad Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Once the central circuit board is lifted, the smaller one can be taken from its holster.
      • After the smaller board is taken out, the wire connecting from the main board to the touchpad motherboard can now be unclipped.
      • Remove the smaller circuit board and the touchpad motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
NathanBatista021
회원 가입일: 03/16/23
497 평판
안내서 4개를 작성함
UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023 회원
UMASSD-RYCKEBUSCH-S23S7G5
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 421
