주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Visioneer OneTouch 7400 USB Motor Replacement
필요한 것
    1. Visioneer OneTouch 7400 USB Motor Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • On the bottom of the scanner, remove the screw at the top left side.
      댓글 쓰기
    2. Visioneer OneTouch 7400 USB Motor Replacement: 2 단계, 이미지 2개 중 1개 Visioneer OneTouch 7400 USB Motor Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      댓글 쓰기
    3. Visioneer OneTouch 7400 USB Motor Replacement: 3 단계, 이미지 3개 중 1개 Visioneer OneTouch 7400 USB Motor Replacement: 3 단계, 이미지 3개 중 2개 Visioneer OneTouch 7400 USB Motor Replacement: 3 단계, 이미지 3개 중 3개
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      댓글 쓰기
    4. Visioneer OneTouch 7400 USB Motor Replacement: 4 단계, 이미지 1개 중 1개
      • Separate the two casement pieces.
      댓글 쓰기
    1. Visioneer OneTouch 7400 USB Motor Replacement, Motor: 5 단계, 이미지 1개 중 1개
      • Carefully detach the wires from the motherboard, pulling slowly but firmly.
      댓글 쓰기
    2. Visioneer OneTouch 7400 USB Motor Replacement: 6 단계, 이미지 2개 중 1개 Visioneer OneTouch 7400 USB Motor Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the four screws holding the motor in place.
      • Note: the pictures hereafter shown are without the motherboard, but you do not have to remove the motherboard to access the motor.
      댓글 쓰기
    3. Visioneer OneTouch 7400 USB Motor Replacement: 7 단계, 이미지 1개 중 1개
      • Lift the motor out of the scanner.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Jena
회원 가입일: 10/18/13
608 평판
안내서 6개를 작성함
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013 회원
UMAINE-DIAZ-F13S1G13
3 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 578
