주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Visioneer OneTouch 7400 USB Sensor Bar Replacement
필요한 것
    1. Visioneer OneTouch 7400 USB Sensor Bar Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • On the bottom of the scanner, remove the screw at the top left side.
      댓글 쓰기
    2. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 2 단계, 이미지 2개 중 1개 Visioneer OneTouch 7400 USB Sensor Bar Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      댓글 쓰기
    3. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 3 단계, 이미지 3개 중 1개 Visioneer OneTouch 7400 USB Sensor Bar Replacement: 3 단계, 이미지 3개 중 2개 Visioneer OneTouch 7400 USB Sensor Bar Replacement: 3 단계, 이미지 3개 중 3개
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      댓글 쓰기
    4. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 4 단계, 이미지 1개 중 1개
      • Separate the two casement pieces.
      댓글 쓰기
    1. Visioneer OneTouch 7400 USB Sensor Bar Replacement, Belt: 5 단계, 이미지 1개 중 1개
      • Remove the screw holding the tension spring in place.
      댓글 쓰기
    2. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 6 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to lift up the tension spring.
      • Be careful. The spring will fly.
      댓글 쓰기
    3. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the belt from the spool.
      • The spool is a loose piece; don't lose it.
      댓글 쓰기
    4. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 8 단계, 이미지 1개 중 1개
      • Loosen the belt enough to turn over the sensor bar.
      댓글 쓰기
    5. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 9 단계, 이미지 2개 중 1개 Visioneer OneTouch 7400 USB Sensor Bar Replacement: 9 단계, 이미지 2개 중 2개
      • With the sensor bar turned upside down, remove the screw in the middle of the bar.
      • Lift off the metal plate if it does not come away with the screw.
      댓글 쓰기
    6. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 10 단계, 이미지 1개 중 1개
      • Carefully lift the belt out of the groove in the sensor bar to remove.
      댓글 쓰기
    1. Visioneer OneTouch 7400 USB Sensor Bar Replacement, Sensor Bar: 11 단계, 이미지 1개 중 1개
      • With the sensor bar upside down, lift the metal tab near the center.
      • Slide the metal casing on top of the sensor bar to the left to disengage it from the plastic.
      댓글 쓰기
    2. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 12 단계, 이미지 1개 중 1개
      • Use the spudger to pry loose the ribbon tab on the inside surface of the casement.
      댓글 쓰기
    3. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 13 단계, 이미지 1개 중 1개
      • Detach the ribbon from the other end and pull the plastic tab from the ribbon.
      댓글 쓰기
    4. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 14 단계, 이미지 2개 중 1개 Visioneer OneTouch 7400 USB Sensor Bar Replacement: 14 단계, 이미지 2개 중 2개
      • Carefully peel the ribbon off of the casing. The ribbon is held with two-sided tape. Use the spudger to help as needed.
      • The ribbon goes under the metal bar. Gently pull the ribbon under the metal bar to remove it.
      댓글 쓰기
    5. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 15 단계, 이미지 2개 중 1개 Visioneer OneTouch 7400 USB Sensor Bar Replacement: 15 단계, 이미지 2개 중 2개
      • Lift the sensor bar from the scanner bed.
      • To finish removing the ribbon from the sensor bar, use the spudger to pry away the clear plastic piece securing the ribbon to the bar. Detach the ribbon from the sensor bar by peeling it away from the double-sided tape.
      댓글 쓰기
    6. Visioneer OneTouch 7400 USB Sensor Bar Replacement: 16 단계, 이미지 1개 중 1개
      • Slowly pull the ribbon end straight out to remove it from the sensor bar.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jena
회원 가입일: 10/18/13
608 평판
안내서 6개를 작성함
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013 회원
UMAINE-DIAZ-F13S1G13
3 회원들
안내서 44개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 722
